I2C read() strange status register in SR2
Question asked by rocca.stephane on Nov 1, 2012
Latest reply on Dec 3, 2012 by koller.kenny
Hi all,
I have a problem on my I2C2 configuration on STM32F4. I try in poll mode first, and I have strange result : write() seems to be ok, but not read() (see comments in code below) :
uint8_t data_received[16];
I2C_GenerateSTART(I2C2, ENABLE);
        while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT)) {
        I2C_Send7bitAddress(I2C2, COMPASS_ADDRESS_ADFAR, I2C_Direction_Receiver);
        while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
        I2C_SendData(I2C2, ConfigRegA   );
        ////////// This will never return from while :
        // while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));    /// SR2 = 00 00 00 00   00 00 01 11    SR1 = 00 00 00 00   10 00 01 00
        ////////// But I can pass this step by doing CUSTOM CHECK
        while (!I2C_CheckEvent(I2C2, 0x00030044));                          /// SR2 = 00 00 00 00   00 00 00 11    SR1 = 00 00 00 00   01 00 01 00
        while (!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED));      /// SR2 = 00 00 00 00   00 00 00 11    SR1 = 00 00 00 00   01 00 00 00
        data_received[0] = I2C_ReceiveData(I2C2);
I2C_GenerateSTOP(I2C2, ENABLE);
So the TRA bit from SR2 register is not set as it should be... But it should be, don't it ?
Thanks in advance for your help
