how to get complementary output at timer CH1 and CH1N ?
Question asked by karakaya.mehmet on Oct 16, 2012
Latest reply on Oct 18, 2012 by Jack Peacock
hello forum,
the processor is STM32F103
I have an H bridge for DC motor
I want complementary outputs of CH1 and CH1N
I setup the timer 1 as following
  TIM_TimeBaseStructure.TIM_Period = 7200;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 2000;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
  TIM_BDTRInitStructure.TIM_DeadTime = 0xCA;
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
  TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;
  TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
then I call below functions to start PWM
however I cant get complemantary output at CH1 and CH1N
I get the same polarity of both CH1 and CH1N ( CH1N is the same as CH1 )
how can I get complementary outputs ?
thank you
    TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
    TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
    TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
    TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_ForcedAction_Active);
    TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Disable);
    TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
