How to disable the write buffer(ACTLR ,DISDEFWBUF)
Question asked by shetty.siddharth on Jun 27, 2012
Latest reply on Jun 27, 2012 by Clive One
Basically my application goes into the hard fault handler(where the IMPRECISERR bit is set) and I have read up about this on some forums and found out that I cannot find out the exact instruction causing this fault However somebody suggested that I disable the write buffer(which is in the ACTLR register). I do not know how to disable this, could you please help? I am writing the code in C, do I need to write some kind of assembly code to assess these registers? Thanks in advance.
