Nichelite / IAR EW / IAR KickStart Kit for STM32F107VC
Question asked by Colin on May 8, 2012
Latest reply on Jun 3, 2012 by Clive One
Hi All,
I'm trying to get Nichelite working with the IAR KickStart Kit for STM32F107VC but so far I'm failing and could do with some help. Has anybody managed to get this going?
So far, I've got everything to compile by removing some duplicate definitions of standard library functions.
I then moved the code from MII mode to RMII mode to allow the Ethernet port to reset correctly and start operating - sort of.
Finally I've changed the PHY address from 1 to 21 to match that used on the Kickstart board.
Unfortunately, that isn't enough to get things running and I'm now rather stuck. The com port works fine and I have the debug interface working - it just doesn't appear to be sending or receiving any packets. The power up DHCP doesn't work and I can't ping it on its default IP address.
Can anybody help me out?
