SRAM with less adress bits - STM32F407IG
Question asked by Neto Godoy on Apr 18, 2012
Latest reply on Apr 21, 2012 by alokm
I'm developing a data acquisition system for a Formula SAE team and the electronic module that I'm designing has a FPGA to acquire multiple digital signals in parallel.
The ideia to read the data stored in the FPGA was to make it look like a SRAM memory, it would have the same functionality and some control and adress bits.
I would like to use the FSMC in SRAM mode with 8 or 16 bits of data and only 3 or 4 bits of adress. Also, I would like to use the other adress bits with other peripherals.
The solution that I came up is to only connect the adress pins that I want to use to the FSMC peripheral and leave the other pins unconnected.
For example, only the [3:0] adress pins would be actually used as adress pins. The [25:4] pins would be internally unconnected to FSMC, but connected to other peripheral of my choice.
Am I missing something or there is no problem with this ideia ?
Thanks and sorry for the bad english!
