Trying to get my STEVAL-PCC010V2 configured for RMII operation, help
Question asked by MOSI on Apr 18, 2012
Latest reply on Apr 19, 2012 by MOSI
Hello. I'm trying to configure my STEVAL-PCC010V2 for RMII operation.
On the STM32F207 board I have selected RMII by fitting SB1and SB2 and removed SB3. I have also removed SB4.
On the ST802RT1A board I have removed SB1, SB2 and SB3. I have also selected RMII by setting JP9 high and JP10 low.
Then I have downloaded STEVAL-PCC010V2 firmware. In main.h I have selected #define RMII_MODE.
But when I compile and run the project it ends up in an endless loop at row 86 in stm32f2x7_eth_bsp.c.
  * @brief  Configures the Ethernet Interface
  * @param  None
  * @retval None
static void ETH_MACDMA_Config(void)
  ETH_InitTypeDef ETH_InitStructure;
  /* Enable ETHERNET clock  */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx |
                        RCC_AHB1Periph_ETH_MAC_Rx, ENABLE);
  /* Reset ETHERNET on AHB Bus */
  ETH_DeInit();
  /* Software reset */
  ETH_SoftwareReset();
  /* Wait for software reset */
  while (ETH_GetSoftwareResetStatus() == SET);    <----- **** gets stuck here ***
  /* ETHERNET Configuration --------------------------------------------------*/
  /* Call ETH_StructInit if you don't like to configure all ETH_InitStructure parameter */
  ETH_StructInit(Ð_InitStructure);
