STM32f103ZE - 6STEP with PWM
Question asked by siqueira.erisson on Feb 23, 2012
Hi, in this example by murat terzi, I have 3phase sinusoidal sine. I would like to know how can I modify the code to defazer 180º one of other to control an ACIM motor. (Logic Analyzer attached file)
* File Name : main.c
* Author : murat terzi
* Version : V2.0.3
* Date : 09/22/2008
* Description : open loop three phase sinusoidal pulse width
modulation for bldc and pmsm motors porta.8, porta.9,porta.10 positive phase outputs
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
#include "stm32f10x_lib.h"
#define ADC1_DR_Address ((u32)0x4001244C)
char i=0;
//sinusoidal data for 256 point
const u16 PWMdata[256]={
2884,2954,3025,3095,3165,3235,3305,3375,3444,3512,
3581,3648,3715,3782,3848,3914,3978,4042,4105,4168,
4229,4290,4349,4408,4466,4522,4578,4633,4686,4738,
4789,4839,4887,4934,4980,5024,5067,5109,5149,5187,
5224,5260,5294,5326,5357,5387,5414,5440,5465,5487,
5508,5528,5545,5561,5575,5588,5598,5607,5614,5614,
5614,5614,5614,5614,5614,5614,5607,5598,5588,5575,
5561,5545,5528,5508,5487,5465,5440,5414,5387,5357,
5326,5294,5260,5224,5187,5149,5109,5067,5024,4980,
4934,4887,4839,4789,4738,4686,4633,4578,4522,4466,
4408,4349,4290,4229,4168,4105,4042,3978,3914,3848,
3782,3715,3648,3581,3512,3444,3375,3305,3235,3165,
3095,3025,2954,2884,2813,2742,2672,2601,2531,2461,
2391,2321,2251,2182,2114,2045,1978,1911,1844,1778,
1712,1648,1584,1521,1458,1397,1336,1277,1218,1160,
1104,1048,993 ,940 ,888 ,837 ,787 ,739 ,692 ,646 ,
602 ,559 ,517 ,477 ,439 ,402 ,366 ,332 ,300 ,269 ,
239 ,212 ,186 ,161 ,139 ,118 ,98 ,81 ,65 ,51 ,
38 ,28 ,19 ,12 ,10 ,10 ,10 ,10 ,10 ,10 ,
12 ,19 ,28 ,38 ,51 ,65 ,81 ,98 ,118 ,139 ,
161 ,186 ,212 ,239 ,269 ,300 ,332 ,366 ,402 ,439 ,
477 ,517 ,559 ,602 ,646 ,692 ,739 ,787 ,837 ,888 ,
940 ,993 ,1048,1104,1160,1218,1277,1336,1397,1458,
1521,1584,1648,1712,1778,1844,1911,1978,2045,2114,
2182,2251,2321,2391,2461,2531,2601,2672,2742,2813,
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
ErrorStatus HSEStartUpStatus;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
* Function Name : main
* Description : Main program
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC configuration */
NVIC_Configuration();
/* GPIO Configuration */
GPIO_Configuration();
/* TIM1 Configuration ---------------------------------------------------
Generates 6 complemantary PWM signals with 4 sinusoidal data duty cycles:
TIM1CLK = 72 MHz, Prescaler = 0, TIM1 counter clock = 72 MHz
TIM1 frequency = TIM1CLK/(TIM1_Period + 1) =
Time Base configuration */
/* TIM1 Peripheral Configuration ----------------------------------------*/
/* Time Base configuration */
TIM_TimeBaseStructure.TIM_Period = 5625-1;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/* Channel 3 Configuration in PWM mode */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = PWMdata[0];//127;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC3Init(TIM1, &TIM_OCInitStructure);
/* Channel 2 Configuration in PWM mode */
TIM_OC2Init(TIM1, &TIM_OCInitStructure);
/* Channel 1 Configuration in PWM mode */
TIM_OCInitStructure.TIM_Pulse = PWMdata[5];//127;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
/* Automatic Output enable, Break, dead time and lock configuration*/
TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
TIM_BDTRInitStructure.TIM_DeadTime = 5;
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;
TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
/* TIM1 counter enable */
//clear tim1 interrupt flag
TIM_ClearFlag(TIM1, TIM_FLAG_CC1);
//TIM1 interrupt source
TIM_ITConfig(TIM1, TIM_IT_CC1, ENABLE);
TIM_Cmd(TIM1, ENABLE);
/* Main Output Enable */
TIM_CtrlPWMOutputs(TIM1, ENABLE);
while (1)
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* ADCCLK = PCLK2/4 */
RCC_ADCCLKConfig(RCC_PCLK2_Div6);
/* PLLCLK = 8MHz * 9 = 72 MHz */
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while (RCC_GetSYSCLKSource() != 0x08)
/* TIM1, GPIOA and GPIOB clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
RCC_APB2Periph_GPIOB|
RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE);
* Function Name : GPIO_Configuration
* Description : Configure the TIM1 Pins.
* Input : None
* Output : None
* Return : None
/* GPIOA Configuration: Channel 1, 2, 3 and 4 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
/* GPIOB Configuration: Channel 1N, 2N and 3N as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
* Function Name : NVIC_Configuration
* Description : Configures Vector Table base location.
* Input : None
* Output : None
* Return : None
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQChannel;
//NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
#ifdef DEBUG
* Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* Input : - file: pointer to the source file name
* - line: assert_param error line source number
* Output : None
* Return : None
void assert_failed(u8* file, u32 line)
while (1)
#endif
/******************* *****END OF FILE****/
void TIM1_CC_IRQHandler(void)
i++;
TIM_OCInitStructure.TIM_Pulse = PWMdata[i];
/* check if array's index reaches the max: 255 */
if (i == 255)
i = 0;
TIM_ClearFlag(TIM1,TIM_FLAG_CC1);
