I2C Problem with STM32F103ze and Sensor
Question asked by eich.alexander on Feb 20, 2012
Latest reply on Feb 20, 2012 by eich.alexander
according to my thread in my native language (german): http://www.mikrocontroller.net/topic/249457#2558731
I wanted to find a solution for my problem.
I have Keil + STM32F103ZE + ITG3200 (http://invensense.com/mems/gyro/documents/PS-ITG-3200-00-01.4.pdf Gyroscope Sensor. Connected on I2C1 and a second ITG3200 sensor on I2C2.
At the moment I'm trying to read out the sensor on I2C1. But I get stucked in the line:
/* Test on EV5 and clear it */while(!I2C_CheckEvent(ITG_I2C, I2C_EVENT_MASTER_MODE_SELECT));
and Line:
ErrorStatus I2C_CheckEvent(I2C_TypeDef* I2Cx, uint32_t I2C_EVENT)
in the STM32f10x_i2c.c
I directly connected SCL (PB6) to the Sensor SCL and the SDA (PB7) to SDA.
My Board uses a 16mhz HSE and the Std.Lib is configured for that.
At the Screenshots in the first links you will see the Clock's and I2C Registers
I attached my code.
Maybe some one has a solution.
Thanks for help
with regards
Sven
//Links:
Link to sensor manual: http://invensense.com/mems/gyro/documents/PS-ITG-3200-00-01.4.pdf
