When I should set the GPIO to open drain mode or push-pull mode?
Question asked by shen.eugene on Jan 12, 2012
Latest reply on Jan 14, 2012 by Andrew Neil
There is a part of codes in the stm324xg_eval_audio_codec.c.
/* CODEC_I2C SCL and SDA pins configuration -------------------------------------*/
  /* If the I2C peripheral is already enabled, don't reconfigure it */
  if ((CODEC_I2C->CR1 & I2C_CR1_PE) != 0)
    GPIO_InitStructure.GPIO_Pin = CODEC_I2C_SCL_PIN | CODEC_I2C_SDA_PIN;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_Init(CODEC_I2C_GPIO, &GPIO_InitStructure);
    /* Connect pins to Periph */
    GPIO_PinAFConfig(CODEC_I2C_GPIO, CODEC_I2S_SCL_PINSRC, CODEC_I2C_GPIO_AF);
    GPIO_PinAFConfig(CODEC_I2C_GPIO, CODEC_I2S_SDA_PINSRC, CODEC_I2C_GPIO_AF);
  /* CODEC_I2S pins configuration: WS, SCK and SD pins -----------------------------*/
  GPIO_InitStructure.GPIO_Pin = CODEC_I2S_WS_PIN | CODEC_I2S_SCK_PIN | CODEC_I2S_SD_PIN;
  GPIO_Init(CODEC_I2S_GPIO, &GPIO_InitStructure);
  /* Connect pins to I2S peripheral  */
  GPIO_PinAFConfig(CODEC_I2S_GPIO, CODEC_I2S_WS_PINSRC, CODEC_I2S_GPIO_AF);
  GPIO_PinAFConfig(CODEC_I2S_GPIO, CODEC_I2S_SCK_PINSRC, CODEC_I2S_GPIO_AF);
  GPIO_PinAFConfig(CODEC_I2S_GPIO, CODEC_I2S_SD_PINSRC, CODEC_I2S_GPIO_AF);
I want to know why I2C and I2S use different modes. By the way, I think
CODEC_I2S_SCL_PINSRC shoud be corrected to CODEC_I2C_SCL_PINSRC.
