Problem with Timing
Question asked by shrestha.durgesh on Jan 4, 2012
Latest reply on Dec 27, 2013 by Clive One
PROBLEM: Timer interrupt is entered immediately in the beginning and not in the desired timing period.
The objective is to enter a service routing of TIM4 with a timing of every 10 sec, clock is 72Mhz:
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseStructure.TIM_Prescaler = 39999;
  TIM_TimeBaseStructure.TIM_ClockDivision = 1;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  // OCMode Active configuration: Channel1
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Active;
  TIM_OCInitStructure.TIM_Pulse = 18000;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OC1Init(TIM4, &TIM_OCInitStructure);
  // interrupt on update
  TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
  TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4, ENABLE);
  // TIM4 enable counter
   TIM_Cmd(TIM4, ENABLE);
The interrupt service routine is entered immediately after the beginning and not after 5 seconds.
I would be happy if someone could help me on this.
