FSMC problem with low address
Question asked by koval.michael on Nov 17, 2011
Latest reply on Nov 18, 2011 by koval.michael
When try to access to SRAM through FSMC (SRAM example from IAR 6.1) I don't see any address on  ADDRESS 7:0. Only high frequancy (> 10 MHz) peaks and splashes. With ADDRESSes 20:8 all OK. With DATA BUS all OK.  Read an Write mode - result is all the same. When disable and enable SRAM result is all the same.  Mix mode is disabled. Bus F ( Low addresses in STM32F207 ) is setted properly. Where is the problem? ( When I try to set bus F as usual  GPIO and toggle pins-  all works OK). Only when FSMC . What is the matter ? Please help !
