I2c2 start bit generation fail in STM32F103RB
Question asked by abuchatzira.aba on May 29, 2011
Latest reply on Jul 6, 2011 by sinha.vikas
Hi, all
I2c2 start bit generation fail - after timeout of 10 ms I2C_FLAG_SB = RESET = 0 but I2c1 work well read and write. anyone can help ?
More details:
10k poll up on each pin.
Clock Speed - 50000.
More details:
my code:
* Function Name  : ISC_Config
* Description    : Configure the ISC interface
* Input          : None
* Output         : None
* Return         : None
void I2C_Config(void)
    I2C_InitTypeDef  I2C_InitStructure;
   /* Configure the SDA And the SCL line to alternate function Open Drain */
    I2C_DeInit(I2C1);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_OD;
    GPIO_Init(I2C_PORT, &GPIO_InitStructure);
    /* Configure the I2C peripheral */
    I2C_SoftwareResetCmd(I2C1,ENABLE);
    I2C_SoftwareResetCmd(I2C1,DISABLE);
    I2C_Cmd(I2C1, DISABLE);
    I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
    I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
    I2C_InitStructure.I2C_OwnAddress1 = I2C_SLAVEADDRESS;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_InitStructure.I2C_ClockSpeed = I2C_CLOCKSPEED;
    I2C_Init(I2C1, &I2C_InitStructure);
    I2C_Cmd(I2C1, ENABLE);
    I2C_AcknowledgeConfig (I2C1, DISABLE);
    I2C_DeInit(I2C2);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;
    I2C_SoftwareResetCmd(I2C2,ENABLE);
    I2C_SoftwareResetCmd(I2C2,DISABLE);
    I2C_Cmd(I2C2, DISABLE);
    I2C_Init(I2C2, &I2C_InitStructure);
    I2C_Cmd(I2C2, ENABLE);
    I2C_AcknowledgeConfig (I2C2, DISABLE);
* Function Name  : GenerateStartCondition
* Description    : Generates the I2C start condition
* Input          : None
* Output         : None
* Return         : TRUE - Start condition generated successfuly. FALSE - otherwise
static BOOL GenerateStartCondition(void)
    BOOL bRes=FALSE;
    BOOL bStatusChangeTimeout=FALSE;
    I2C_GenerateSTART (I2C2, ENABLE);
    if (TriggerTimeoutCounter(I2C_STATUS_CHANGE_TIMEOUT_MSEC))
        while ((I2C_GetFlagStatus (I2C2,I2C_FLAG_SB)== RESET) && !bStatusChangeTimeout)
            if (IsTimeoutExpired())
                  bStatusChangeTimeout=TRUE;
        if (!bStatusChangeTimeout)
            bRes=TRUE;
    return bRes;
main()
        return GenerateStartCondition(); //it's return false
