suggestions for 2 MSPS ADC on 2 channels, DSP processing and results to PC or R-PI
Question asked by cannistra.mario on Nov 9, 2016
Latest reply on Nov 18, 2016 by cannistra.mario
Hi all.
I'm new to this platform, checking if I could use it in this scenario.
Which kit / evaluation module / board would you suggest in order to test/evaluate this build:
1) acquire 2 analog values on separate channels at fast rate (> 2 MSPS) , minimum 12 bit for each value, better if higher
2) optionally perform some DSP processing (is FFT on a data buffer available?)
3) send raw data or FFT results to Raspberry PI or PC via another fast interface, could be USB high speed
Thank you,
Mario
