nucleo446re and MPU6050 i2c problem
Question asked by sohaeng.lee on Sep 6, 2016
Latest reply on Sep 8, 2016 by FTITI.Walid
hi
why 'HAL_I2C_IsDeviceReady' is always 'BUSY'?
using board : Nucleo-F446RE , MPU6050
Library : HAL
here is my source code -----------------
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f4xx_hal.h"
#include "tlcd.h"
#include "my_mpu6050.h"
/* USER CODE END Includes */
I2C_HandleTypeDef hi2c1;
DMA_HandleTypeDef hdma_i2c1_rx;
DMA_HandleTypeDef hdma_i2c1_tx;
TIM_HandleTypeDef htim2;
TIM_HandleTypeDef htim3;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
#define DATA  10
uint8_t Rx_Buffer2[DATA];
uint8_t Rx_Data2[2];
uint8_t Rx_Indx2;
uint8_t Transfer_cplt2;
__IO uint8_t i2c_data[20];
volatileuint32_t count=0;
/* USER CODE END PV */
voidSystemClock_Config(void);
voidError_Handler(void);
staticvoidMX_GPIO_Init(void);
staticvoidMX_DMA_Init(void);
staticvoidMX_TIM2_Init(void);
staticvoidMX_TIM3_Init(void);
staticvoidMX_USART2_UART_Init(void);
staticvoidMX_I2C1_Init(void);
/* USER CODE BEGIN PFP */
void          HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart);
void          HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim);
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
voidHAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
     uint8_t     i;
     HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
     if(huart->Instance==USART2)
          if(Rx_Indx2==0)
               for(i=0;i<DATA;i++) Rx_Buffer2[i] = 0;
          if(Rx_Data2[0]!=0x0d)
               Rx_Buffer2[Rx_Indx2++]=Rx_Data2[0];
          else
               Rx_Indx2 = 0;
               Transfer_cplt2 = 1;
          HAL_UART_Receive_IT(&huart2, Rx_Data2, 1);
          HAL_UART_Transmit(&huart2, Rx_Data2, 1,1000);
voidHAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
     if(htim->Instance==TIM2) {
          // HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin);
//          HAL_UART_Transmit(&huart2, (uint8_t *)"Start!!!!!\r\n", 12,1000);
     elseif(htim->Instance==TIM3) {
/* USER CODE END 0 */
intmain(void)
  /* USER CODE BEGIN 1 */
     char s1[17] = "**1234567890**";
     char s2[17] = "**ABCDEFGHIJ**";
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_TIM2_Init();
  MX_TIM3_Init();
  MX_USART2_UART_Init();
  MX_I2C1_Init();
  /* USER CODE BEGIN 2 */
     while(HAL_UART_Receive_IT(&huart2, Rx_Data2, 1)!=HAL_OK);
     // Activate TIMER Interrupt
     while(HAL_TIM_Base_Start_IT(&htim2)!=HAL_OK);
     while(HAL_TIM_Base_Start_IT(&htim3)!=HAL_OK);
     //  i2c1 setting
     uint8_t whoAmI[2];
//     whoAmI[0] = RA_PWR_ADDR;
//     whoAmI[1] = RA_PWR_MGMT_1;
     uint8_t  pdata=0x00;
     while(HAL_I2C_IsDeviceReady(&hi2c1,MPU6050,10,1000)!=HAL_OK);
     HAL_I2C_Master_Transmit_DMA(&hi2c1,MPU6050,&pdata,1);
     HAL_I2C_Mem_Write_DMA(&hi2c1,MPU6050>>1,RA_PWR_ADDR,1,&pdata,1);
     HAL_UART_Transmit(&huart2, (uint8_t *)"\r\n11111!!!!!\r\n", 14,1000);
     while(HAL_I2C_GetState(&hi2c1)!=HAL_I2C_STATE_READY);
     HAL_UART_Transmit(&huart2, (uint8_t *)"\r\n22222!!!!!\r\n", 14,1000);
     while(HAL_I2C_Master_Receive_DMA(&hi2c1,MPU6050,whoAmI,2)!=HAL_OK);
     HAL_UART_Transmit(&huart2, (uint8_t *)"\r\n33333!!!!!\r\n", 14,1000);
     //HAL_I2C_Master_Receive_DMA(&hi2c1,0x68,(uint8_t *)i2c_data,7);
     // HAL_I2C_Mem_Read_DMA(&hi2c1,0x69,0x3b,14,(uint8_t *)i2c_data,14);
     //while(HAL_I2C_Master_Receive_IT(&hi2c1,i2c_buffer,1) != HAL_OK );
     // ADC - DMA
     char sss[10];
     HAL_UART_Transmit(&huart2, (uint8_t *)"\r\nStart!!!!!\r\n", 14,1000);
     sprintf(sss,"%2x,%2x\r\n",whoAmI[0],whoAmI[1]);
     HAL_UART_Transmit(&huart2, sss, 10,1000);
     // LCD사용을 위해 GPIOC를 사용.
     TLCD_Init(GPIO_PIN_10,GPIO_PIN_11,GPIO_PIN_0,GPIO_PIN_1,GPIO_PIN_2,GPIO_PIN_3);
     TLCD_Puts(1,s1);
     TLCD_Puts(2,s2);
     HAL_Delay(3000000);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
          TLCD_Puts(1," *Init    Gyro*");
          TLCD_Puts(2," *InIt   Motor*");
          HAL_Delay(1000000);
          TLCD_Puts(1," *InIt   Motor*");
          TLCD_Puts(2," *Init    Gyro*");
          HAL_Delay(1000000);
          HAL_UART_Transmit(&huart2, (uint8_t *)"\r\nwhile!!!!!\r\n", 14,1000);
  /* USER CODE END 3 */
/** System Clock Configuration
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 180;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
    Error_Handler();
  if (HAL_PWREx_EnableOverDrive() != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000000);
/* I2C1 init function */
  hi2c1.Instance = I2C1;
  hi2c1.Init.ClockSpeed = 100000;
  hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
  hi2c1.Init.OwnAddress1 = 0;
  hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c1.Init.OwnAddress2 = 0;
  hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c1) != HAL_OK)
    Error_Handler();
/* TIM2 init function */
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 9000;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 4999;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
    Error_Handler();
/* TIM3 init function */
  htim3.Instance = TIM3;
  htim3.Init.Prescaler = 9000;
  htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim3.Init.Period = 9999;
  htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
    Error_Handler();
  if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
    Error_Handler();
/* USART2 init function */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  * Enable DMA controller clock
  __HAL_RCC_DMA1_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA1_Stream0_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Stream0_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Stream0_IRQn);
  /* DMA1_Stream6_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Stream6_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Stream6_IRQn);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PC0 PC1 PC2 PC3
                           PC8 PC9 PC10 PC11 */
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11;
  /*Configure GPIO pin : LD2_Pin */
  GPIO_InitStruct.Pin = LD2_Pin;
  HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
