Linux driver for the CR95HF-based board
Question asked by campana.ottavio on Aug 22, 2013
Latest reply on Nov 13, 2015 by NFC software support 3
Hello, I am trying to make my m24lr discovery board work under Linux.
I've seen that ST provides a DLL to communicate with the green board under windows, but I'd like to use it under Linux. As far as I've seen, it is a HID device, but even by reading the source codice for its microcontroller, I've been only able to understand that the firmware forwards the commands to the CR95HF, but I was not able to understand the format of the commands.
Do you have a working code to use that board under linux? Or do you have a bit more documentation, so that I can try to use the board with libusb?
Thank you
Ottavio
