VREFINT, Temperature sensor always returns 4095 value (STM32F3 Discovery board)
Question asked by bui.cuong on May 1, 2016
Latest reply on May 2, 2016 by bui.cuong
I made a test with ADC on STM32F3 Discovery, using STM32F303VCT6 chip. The test is reading VREFINT, Temperature Sensor. Both readings always return 4095 (max value).
The code was generated by CubeMX, using HAL driver. ADC clocks from PLL/4, 18MHz. Here are my codes. Printed value of ADC12_CCR is 0x400000, confirmed that VREFEN bit is set by function HAL_ADC_ConfigChannel().
File main.c:
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f3xx_hal.h"
/* USER CODE END Includes */
ADC_HandleTypeDef hadc1;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_ADC1_Init(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
uint8_t txBuffer[30] = "Waiting\n";
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_ADC1_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  HAL_UART_Transmit(&huart1, txBuffer, strlen((char*)txBuffer), 1000);
  ADC_Common_TypeDef *tmpADC_Common;
  tmpADC_Common = ADC_COMMON_REGISTER(&hadc1);
  uint32_t valCCR = 0;
  HAL_ADC_Start(&hadc1);
  uint16_t adcPollVal = 0;
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
      if( HAL_ADC_PollForConversion(&hadc1, 1000) == HAL_OK) {
          HAL_GPIO_TogglePin(GPIOE, LD5_ORANGE_LED_Pin);
          adcPollVal = HAL_ADC_GetValue(&hadc1);
          sprintf((char*)txBuffer, "Channel ADC1-Vrefint: %d (value) \n", adcPollVal);
          valCCR = tmpADC_Common->CCR;
          sprintf((char*)txBuffer, "Channel ADC1-CCR: %X (value) \n", valCCR);
          HAL_Delay(400);
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_ADC12;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInit.Adc12ClockSelection = RCC_ADC12PLLCLK_DIV4;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
/* ADC1 init function */
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  HAL_ADC_Init(&hadc1);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_VREFINT;
  sConfig.Rank = 1;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.SamplingTime = ADC_SAMPLETIME_601CYCLES_5;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&hadc1, &sConfig);
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  HAL_UART_Init(&huart1);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOF_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOE_CLK_ENABLE();
  /*Configure GPIO pin : USER_BTN_Pin */
  GPIO_InitStruct.Pin = USER_BTN_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(USER_BTN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : LD4_BLUE_LED_Pin LD3_RED_LED_Pin LD7_GREEN_LED_Pin LD9_BLUE_LED_Pin
                           LD6_GREEN_LED_Pin */
  GPIO_InitStruct.Pin = LD4_BLUE_LED_Pin|LD3_RED_LED_Pin|LD7_GREEN_LED_Pin|LD9_BLUE_LED_Pin
                          |LD6_GREEN_LED_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : LD5_ORANGE_LED_Pin LD10_RED_LED_Pin LD8_ORANGE_LED_Pin */
  GPIO_InitStruct.Pin = LD5_ORANGE_LED_Pin|LD10_RED_LED_Pin|LD8_ORANGE_LED_Pin;
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOE, LD4_BLUE_LED_Pin|LD3_RED_LED_Pin|LD5_ORANGE_LED_Pin|LD7_GREEN_LED_Pin
                          |LD9_BLUE_LED_Pin|LD10_RED_LED_Pin|LD8_ORANGE_LED_Pin|LD6_GREEN_LED_Pin, GPIO_PIN_RESET);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
