Cannot write M24LR64E-R after MCU read a sensor Value
Question asked by tchouga.yannick on Feb 24, 2015
Latest reply on Jun 26, 2015 by ST NFC
For a project I use the M24LR64E-R as memory and power supply. Everything works very well if I want to read or write the M24LR64E-R. But as soon as I read another sensor, this sensor value cannot write to the M24LR64E-R. For this application I use the MCU MSP430FR of TI.
Following ANs I've read:
AN1471 (http://www.st.com/web/en/resource/technical/document/application_note/CD00004295.pdf )
AN3057
(http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00247968.pdf )
Errata sheet for M24LRXXE-R
(http://www.st.com/st-web-ui/static/active/en/resource/technical/document/errata_sheet/DM00052762.pdf )
But I don´t see any solution.
Questions:
1-      1- Can we use the M24LR64E-R constantly on the RF Field (For power supply)? And at the same time using the I2C bus with other sensors? (This has been going when I use only the MSP430 and the M24LR64E-R).
2-      2- Does anyone have used the M24LR64E-R as active Tag without a battery? (Always in the RF field but without command).
Thanks for the help.
Yannick.
