SPC560D30L3 - PWM output on channel 1
Question asked by Mike on Mar 16, 2015
Latest reply on Mar 19, 2015 by Erwan Y
Hello Members,
I am trying to generate the PWM output on channel 1. As per my understanding, channel 0 is PA9, channel 1 is PA10 and so on. I am using the test application "SPC560Dxx OS-Less PWM-ICU Test Application" for this. I performed following steps,
1. Changed the platform component to SPC560D30L3.
2. Tested the app for PWM on channel 0 (PA9) and it is working fine.
3. I changed the PA9 to PA10.
4. Under HAL drivers, I modified the eMIOS settings for channel 1. (i.e. disabled ch 0 and enabled ch 1, keeping the callback function names as it is)
5. Generate application and build the project.
6. Debug and test
I am not getting the PWM output on ch 1 (PA10). What is the reason? Is any other settings are required for this?
Your earliest help in this regard will be highly appreciated. Thanks in advance.
Mike.
