LIS3DH scale factor? 1g = 16600. Not 1mg/digit!
Question asked by MOSI on Sep 29, 2014
Latest reply on May 11, 2017 by Anusuya Nallathambi
I'm testing a LIS3DH and set the FS bit to 00 (+/-2g measurement range).
I get about 16600 at 1g. The datasheet says 1mg/digit.
Then I found in another application note (AN3182) that the sensor uses 12 bits left justified values. This could explain why I get this result.
Could anybody explain this?
What value should I get if I activate the self test? The datasheet says 276 for Ax. So this should be 276x16 = 4416?
I think the datasheet should need some rework to make things more clear.
