Problems to connect two SPWF01SA via TCP or UDP socket
Question asked by hildenbrand.manuel on May 27, 2015
Latest reply on Jun 2, 2015 by Gerardo Gallucci
i´m from Germany, therefore please apologize my mediocre english ;).
I have some problems with the module SPWF01SA. I want to connect them both to each other. One SPWF01SA is configured in the MiniAP mode. The other one have to connect to this AP via Access point connection.
The Problem is, every time the SPWF01SA will join to the other SPWF01SA (with MINIAP), the client module reboot an starts new. This ends in an continuous Loop. On both modules the Firmware SPWF01S-140805-3f58d6b-RELEASE-main is installed.
It would be great if someone can help me. Thank you very much.
Configuration:
MINI AP:
+WIND:1:Poweron (140805-3f58d6b-SPWF01S)
+WIND:13:ST SPWF01SA IWM: Copyright (c) 2012-2014 STMicroelectronics, Inc.  All rights Reserved.
+WIND:3:Watchdog Running
+WIND:0:Console active
+WIND:32:WiFi Hardware Started
+WIND:26:WiFi Started AP with network 'ADHOC'
+WIND:24:WiFi Up:172.31.245.1
Settings:
# Dumping All Configuration Keys:
#  nv_manuf = ST
#  nv_model = SPWF01SA
#  nv_serial = 4313D03299
#  nv_wifi_macaddr = 00:80:E1:FF:99:F5
#  blink_led = 0
#  wind_off_low = 0x00000000
#  wind_off_medium = 0x00000000
#  wind_off_high = 0x00000000
#  user_desc = anonymous
#  escape_seq = at+s.
#  localecho1 = 0
#  console1_speed = 115200
#  console1_hwfc = 0
#  console1_enabled = 1
#  sleep_enabled = 0
#  standby_enabled = 0
#  standby_time = 10
#  wifi_tx_msdu_lifetime = 0
#  wifi_rx_msdu_lifetime = 0
#  wifi_operational_mode = 0x00000011
#  wifi_beacon_wakeup = 1
#  wifi_beacon_interval = 100
#  wifi_listen_interval = 0
#  wifi_rts_threshold = 3000
#  wifi_ssid = 41:44:48:4F:43:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_ssid_len = 5
#  wifi_channelnum = 6
#  wifi_opr_rate_mask = 0x00003FCF
#  wifi_bas_rate_mask = 0x0000000F
#  wifi_mode = 3
#  wifi_auth_type = 0
#  wifi_atim_window = 0
#  wifi_powersave = 0
#  wifi_tx_power = 18
#  wifi_rssi_thresh = 0
#  wifi_rssi_hyst = 0
#  wifi_ap_idle_timeout = 120
#  wifi_beacon_loss_thresh = 10
#  wifi_priv_mode = 0
#  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_key_lens = 00:00:00:00
#  wifi_wep_default_key = 0
#  wifi_wpa_psk_raw = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wpa_psk_text = test
#  ip_use_dhcp = 1
#  ip_use_httpd = 1
#  ip_mtu = 1500
#  ip_hostname = iwm-FF-99-F5
#  ip_apdomainname = captiveportal.net
#  ip_ipaddr = 192.168.1.2
#  ip_netmask = 255.255.255.0
#  ip_gw = 192.168.1.1
#  ip_dns = 192.168.1.1
#  ip_http_get_recv_timeout = 3000
#  ip_dhcp_timeout = 20
Client Module:
+WIND:21:WiFi Scanning
+WIND:35:WiFi Scan Complete (0x0)
+WIND:19:WiFi Join:00:80:E1:FF:99:F5
Settings:
#  nv_manuf = ST
#  nv_serial = 4313D17299
#  nv_wifi_macaddr = 00:80:E1:FF:9A:08
#  blink_led = 0
#  localecho1 = 0
#  console1_hwfc = 0
#  sleep_enabled = 0
#  standby_time = 10
#  wifi_ssid = 41:44:48:4F:43:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00                                          :00:00:00:00:00:00:00:00:00:00
#  wifi_ssid_len = 5
#  wifi_mode = 1
#  wifi_wpa_psk_raw = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:0                                          0:00:00:00:00:00:00:00:00:00:00:00:00
#  ip_use_dhcp = 1
#  ip_use_httpd = 1
#  ip_mtu = 1500
#  ip_hostname = iwm-FF-9A-08
#  ip_ipaddr = 192.168.0.50
#  ip_gw = 192.168.0.1
#  ip_dns = 192.168.0.1
Sincerely
Manuel H.
