[STM32F7 Discovery] - LTDC
Question asked by Noto.Federico on Oct 30, 2015
Latest reply on Nov 2, 2015 by Nesrine M
I want to learn about programming the display to show something, well, for now its ok just display a color layer.
I used STMCUBEMX, using default config of LTDC (RGB 565).
I generated the code and found a convenient MX_LTDC_Init(); on main. The current definition of MX_LTDC_Init() looks like it should turn on the display and show the default layer....but after flashing the code, the display even, EVEN!, powers on.
So, could you please tell me, kindly and without hating me, why this code it isn't working ?
Thanks again.
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2015 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f7xx_hal.h"
/* USER CODE END Includes */
LTDC_HandleTypeDef hltdc;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_LTDC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_LTDC_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
  __PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLM = 10;
  RCC_OscInitStruct.PLL.PLLN = 210;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
  PeriphClkInitStruct.PLLSAI.PLLSAIN = 192;
  PeriphClkInitStruct.PLLSAI.PLLSAIR = 2;
  PeriphClkInitStruct.PLLSAI.PLLSAIQ = 2;
  PeriphClkInitStruct.PLLSAI.PLLSAIP = RCC_PLLSAIP_DIV2;
  PeriphClkInitStruct.PLLSAIDivQ = 1;
  PeriphClkInitStruct.PLLSAIDivR = RCC_PLLSAIDIVR_2;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
/* LTDC init function */
  LTDC_LayerCfgTypeDef pLayerCfg;
  LTDC_LayerCfgTypeDef pLayerCfg1;
  hltdc.Instance = LTDC;
  hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
  hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
  hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
  hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
  hltdc.Init.HorizontalSync = 7;
  hltdc.Init.VerticalSync = 3;
  hltdc.Init.AccumulatedHBP = 14;
  hltdc.Init.AccumulatedVBP = 5;
  hltdc.Init.AccumulatedActiveW = 654;
  hltdc.Init.AccumulatedActiveH = 485;
  hltdc.Init.TotalWidth = 660;
  hltdc.Init.TotalHeigh = 487;
  hltdc.Init.Backcolor.Blue = 0;
  hltdc.Init.Backcolor.Green = 255;
  hltdc.Init.Backcolor.Red = 0;
  HAL_LTDC_Init(&hltdc);
  pLayerCfg.WindowX0 = 0;
  pLayerCfg.WindowX1 = 0;
  pLayerCfg.WindowY0 = 0;
  pLayerCfg.WindowY1 = 0;
  pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
  pLayerCfg.Alpha = 0;
  pLayerCfg.Alpha0 = 0;
  pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
  pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
  pLayerCfg.FBStartAdress = 0;
  pLayerCfg.ImageWidth = 0;
  pLayerCfg.ImageHeight = 0;
  pLayerCfg.Backcolor.Blue = 0;
  pLayerCfg.Backcolor.Green = 0;
  pLayerCfg.Backcolor.Red = 0;
  HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0);
  pLayerCfg1.WindowX0 = 0;
  pLayerCfg1.WindowX1 = 0;
  pLayerCfg1.WindowY0 = 0;
  pLayerCfg1.WindowY1 = 0;
  pLayerCfg1.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
  pLayerCfg1.Alpha = 0;
  pLayerCfg1.Alpha0 = 0;
  pLayerCfg1.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
  pLayerCfg1.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
  pLayerCfg1.FBStartAdress = 0;
  pLayerCfg1.ImageWidth = 0;
  pLayerCfg1.ImageHeight = 0;
  pLayerCfg1.Backcolor.Blue = 0;
  pLayerCfg1.Backcolor.Green = 255;
  pLayerCfg1.Backcolor.Red = 0;
  HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg1, 1);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
     PE2   ------> QUADSPI_BK1_IO2
     PG14   ------> ETH_TXD1
     PE1   ------> FMC_NBL1
     PE0   ------> FMC_NBL0
     PB8   ------> I2C1_SCL
     PB5   ------> USB_OTG_HS_ULPI_D7
     PB4   ------> S_TIM3_CH1
     PD7   ------> SPDIFRX_IN0
     PC12   ------> SDMMC1_CK
     PA15   ------> S_TIM2_CH1_ETR
     PE5   ------> DCMI_D6
     PE6   ------> DCMI_D7
     PG13   ------> ETH_TXD0
     PB9   ------> I2C1_SDA
     PB7   ------> USART1_RX
     PB6   ------> QUADSPI_BK1_NCS
     PG15   ------> FMC_SDNCAS
     PG11   ------> ETH_TX_EN
     PD0   ------> FMC_D2_DA2
     PC11   ------> SDMMC1_D3
     PC10   ------> SDMMC1_D2
     PA12   ------> USB_OTG_FS_DP
     PI4   ------> SAI2_MCLK_A
     PG10   ------> SAI2_SD_B
     PD3   ------> DCMI_D5
     PD1   ------> FMC_D3_DA3
     PA11   ------> USB_OTG_FS_DM
     PF0   ------> FMC_A0
     PI5   ------> SAI2_SCK_A
     PI7   ------> SAI2_FS_A
     PI6   ------> SAI2_SD_A
     PG9   ------> DCMI_VSYNC
     PD2   ------> SDMMC1_CMD
     PI1   ------> SPI2_SCK
     PA10   ------> USB_OTG_FS_ID
     PF1   ------> FMC_A1
     PH14   ------> DCMI_D4
     PI0   ------> S_TIM5_CH4
     PA9   ------> USART1_TX
     PC9   ------> SDMMC1_D1
     PA8   ------> RCC_MCO_1
     PF2   ------> FMC_A2
     PC8   ------> SDMMC1_D0
     PC7   ------> USART6_RX
     PF3   ------> FMC_A3
     PH4   ------> USB_OTG_HS_ULPI_NXT
     PG8   ------> FMC_SDCLK
     PC6   ------> USART6_TX
     PF4   ------> FMC_A4
     PH5   ------> FMC_SDNWE
     PH3   ------> FMC_SDNE0
     PF7   ------> ADC3_IN5
     PF6   ------> ADC3_IN4
     PF5   ------> FMC_A5
     PD15   ------> FMC_D1_DA1
     PB13   ------> USB_OTG_HS_ULPI_D6
     PD10   ------> FMC_D15_DA15
     PF10   ------> ADC3_IN8
     PF9   ------> ADC3_IN7
     PF8   ------> ADC3_IN6
     PC3   ------> FMC_SDCKE0
     PD14   ------> FMC_D0_DA0
     PB12   ------> USB_OTG_HS_ULPI_D5
     PD9   ------> FMC_D14_DA14
     PD8   ------> FMC_D13_DA13
     PC0   ------> USB_OTG_HS_ULPI_STP
     PC1   ------> ETH_MDC
     PC2   ------> USB_OTG_HS_ULPI_DIR
     PB2   ------> QUADSPI_CLK
     PF12   ------> FMC_A6
     PG1   ------> FMC_A11
     PF15   ------> FMC_A9
     PD12   ------> QUADSPI_BK1_IO1
     PD13   ------> QUADSPI_BK1_IO3
     PH12   ------> DCMI_D3
     PA1   ------> ETH_REF_CLK
     PA0/WKUP   ------> ADCx_IN0
     PA4   ------> DCMI_HSYNC
     PC4   ------> ETH_RXD0
     PF13   ------> FMC_A7
     PG0   ------> FMC_A10
     PE8   ------> FMC_D5_DA5
     PD11   ------> QUADSPI_BK1_IO0
     PG5   ------> FMC_A15_BA1
     PG4   ------> FMC_A14_BA0
     PH7   ------> I2C3_SCL
     PH9   ------> DCMI_D0
     PH11   ------> DCMI_D2
     PA2   ------> ETH_MDIO
     PA6   ------> DCMI_PIXCLK
     PA5   ------> USB_OTG_HS_ULPI_CK
     PC5   ------> ETH_RXD1
     PF14   ------> FMC_A8
     PF11   ------> FMC_SDNRAS
     PE9   ------> FMC_D6_DA6
     PE11   ------> FMC_D8_DA8
     PE14   ------> FMC_D11_DA11
     PB10   ------> USB_OTG_HS_ULPI_D3
     PH6   ------> S_TIM12_CH1
     PH8   ------> I2C3_SDA
     PH10   ------> DCMI_D1
     PA3   ------> USB_OTG_HS_ULPI_D0
     PA7   ------> ETH_CRS_DV
     PB1   ------> USB_OTG_HS_ULPI_D2
     PB0   ------> USB_OTG_HS_ULPI_D1
     PE7   ------> FMC_D4_DA4
     PE10   ------> FMC_D7_DA7
     PE12   ------> FMC_D9_DA9
     PE15   ------> FMC_D12_DA12
     PE13   ------> FMC_D10_DA10
     PB11   ------> USB_OTG_HS_ULPI_D4
     PB14   ------> SPI2_MISO
     PB15   ------> SPI2_MOSI
  /* GPIO Ports Clock Enable */
  __GPIOE_CLK_ENABLE();
  __GPIOG_CLK_ENABLE();
  __GPIOB_CLK_ENABLE();
  __GPIOD_CLK_ENABLE();
  __GPIOC_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  __GPIOJ_CLK_ENABLE();
  __GPIOI_CLK_ENABLE();
  __GPIOK_CLK_ENABLE();
  __GPIOF_CLK_ENABLE();
  __GPIOH_CLK_ENABLE();
  /*Configure GPIO pin : OTG_HS_OverCurrent_Pin */
  GPIO_InitStruct.Pin = OTG_HS_OverCurrent_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(OTG_HS_OverCurrent_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : QSPI_D2_Pin */
  GPIO_InitStruct.Pin = QSPI_D2_Pin;
  GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF9_QUADSPI;
  HAL_GPIO_Init(QSPI_D2_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : RMII_TXD1_Pin RMII_TXD0_Pin RMII_TX_EN_Pin */
  GPIO_InitStruct.Pin = RMII_TXD1_Pin|RMII_TXD0_Pin|RMII_TX_EN_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  /*Configure GPIO pins : PE1 PE0 FMC_D5_Pin FMC_D6_Pin
                           FMC_D8_Pin FMC_D11_Pin FMC_D4_Pin FMC_D7_Pin
                           FMC_D9_Pin FMC_D12_Pin FMC_D10_Pin */
  GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_0|FMC_D5_Pin|FMC_D6_Pin
                          |FMC_D8_Pin|FMC_D11_Pin|FMC_D4_Pin|FMC_D7_Pin
                          |FMC_D9_Pin|FMC_D12_Pin|FMC_D10_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF12_FMC;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : ARDUINO_SCL_D15_Pin ARDUINO_SDA_D14_Pin */
  GPIO_InitStruct.Pin = ARDUINO_SCL_D15_Pin|ARDUINO_SDA_D14_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
  /*Configure GPIO pins : ULPI_D7_Pin ULPI_D6_Pin ULPI_D5_Pin ULPI_D3_Pin
                           ULPI_D2_Pin ULPI_D1_Pin ULPI_D4_Pin */
  GPIO_InitStruct.Pin = ULPI_D7_Pin|ULPI_D6_Pin|ULPI_D5_Pin|ULPI_D3_Pin
                          |ULPI_D2_Pin|ULPI_D1_Pin|ULPI_D4_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF10_OTG_HS;
  /*Configure GPIO pin : ARDUINO_PWM_D3_Pin */
  GPIO_InitStruct.Pin = ARDUINO_PWM_D3_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF2_TIM3;
  HAL_GPIO_Init(ARDUINO_PWM_D3_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : SPDIF_RX0_Pin */
  GPIO_InitStruct.Pin = SPDIF_RX0_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF8_SPDIFRX;
  HAL_GPIO_Init(SPDIF_RX0_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : SDMMC_CK_Pin SDMMC_D3_Pin SDMMC_D2_Pin PC9
                           PC8 */
  GPIO_InitStruct.Pin = SDMMC_CK_Pin|SDMMC_D3_Pin|SDMMC_D2_Pin|GPIO_PIN_9
                          |GPIO_PIN_8;
  GPIO_InitStruct.Alternate = GPIO_AF12_SDMMC;
  /*Configure GPIO pin : ARDUINO_PWM_D9_Pin */
  GPIO_InitStruct.Pin = ARDUINO_PWM_D9_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF1_TIM2;
  HAL_GPIO_Init(ARDUINO_PWM_D9_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PE5 PE6 */
  GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_6;
  GPIO_InitStruct.Alternate = GPIO_AF13_DCMI;
  /*Configure GPIO pin : VCP_RX_Pin */
  GPIO_InitStruct.Pin = VCP_RX_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
  HAL_GPIO_Init(VCP_RX_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : QSPI_NCS_Pin */
  GPIO_InitStruct.Pin = QSPI_NCS_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF10_QUADSPI;
  HAL_GPIO_Init(QSPI_NCS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PG15 PG8 PG1 PG0
                           FMC_BA1_Pin FMC_BA0_Pin */
  GPIO_InitStruct.Pin = GPIO_PIN_15|GPIO_PIN_8|GPIO_PIN_1|GPIO_PIN_0
                          |FMC_BA1_Pin|FMC_BA0_Pin;
  /*Configure GPIO pin : OTG_FS_VBUS_Pin */
  GPIO_InitStruct.Pin = OTG_FS_VBUS_Pin;
  HAL_GPIO_Init(OTG_FS_VBUS_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : Audio_INT_Pin */
  GPIO_InitStruct.Pin = Audio_INT_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  HAL_GPIO_Init(Audio_INT_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : FMC_D2_Pin FMC_D3_Pin FMC_D1_Pin FMC_D15_Pin
                           FMC_D0_Pin FMC_D14_Pin FMC_D13_Pin */
  GPIO_InitStruct.Pin = FMC_D2_Pin|FMC_D3_Pin|FMC_D1_Pin|FMC_D15_Pin
                          |FMC_D0_Pin|FMC_D14_Pin|FMC_D13_Pin;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : OTG_FS_P_Pin OTG_FS_N_Pin OTG_FS_ID_Pin */
  GPIO_InitStruct.Pin = OTG_FS_P_Pin|OTG_FS_N_Pin|OTG_FS_ID_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS;
  /*Configure GPIO pins : SAI2_MCLKA_Pin SAI2_SCKA_Pin SAI2_FSA_Pin SAI2_SDA_Pin */
  GPIO_InitStruct.Pin = SAI2_MCLKA_Pin|SAI2_SCKA_Pin|SAI2_FSA_Pin|SAI2_SDA_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF10_SAI2;
  HAL_GPIO_Init(GPIOI, &GPIO_InitStruct);
  /*Configure GPIO pin : SAI2_SDB_Pin */
  GPIO_InitStruct.Pin = SAI2_SDB_Pin;
  HAL_GPIO_Init(SAI2_SDB_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : OTG_FS_PowerSwitchOn_Pin */
  GPIO_InitStruct.Pin = OTG_FS_PowerSwitchOn_Pin;
  HAL_GPIO_Init(OTG_FS_PowerSwitchOn_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PD3 */
  GPIO_InitStruct.Pin = GPIO_PIN_3;
  /*Configure GPIO pins : ARDUINO_D7_Pin ARDUINO_D8_Pin LCD_DISP_Pin */
  GPIO_InitStruct.Pin = ARDUINO_D7_Pin|ARDUINO_D8_Pin|LCD_DISP_Pin;
  /*Configure GPIO pin : uSD_Detect_Pin */
  GPIO_InitStruct.Pin = uSD_Detect_Pin;
  HAL_GPIO_Init(uSD_Detect_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PF0 PF1 PF2 PF3
                           PF4 PF5 PF12 PF15
                           PF13 PF14 PF11 */
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_12|GPIO_PIN_15
                          |GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_11;
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  /*Configure GPIO pin : LCD_BL_CTRL_Pin */
  GPIO_InitStruct.Pin = LCD_BL_CTRL_Pin;
  HAL_GPIO_Init(LCD_BL_CTRL_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PG9 */
  GPIO_InitStruct.Pin = GPIO_PIN_9;
  /*Configure GPIO pin : OTG_FS_OverCurrent_Pin */
  GPIO_InitStruct.Pin = OTG_FS_OverCurrent_Pin;
  HAL_GPIO_Init(OTG_FS_OverCurrent_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : SDMMC_D0_Pin */
  GPIO_InitStruct.Pin = SDMMC_D0_Pin;
  HAL_GPIO_Init(SDMMC_D0_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : TP3_Pin NC2_Pin */
  GPIO_InitStruct.Pin = TP3_Pin|NC2_Pin;
  HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
  /*Configure GPIO pin : ARDUINO_SCK_D13_Pin */
  GPIO_InitStruct.Pin = ARDUINO_SCK_D13_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
  HAL_GPIO_Init(ARDUINO_SCK_D13_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : DCMI_PWR_EN_Pin */
  GPIO_InitStruct.Pin = DCMI_PWR_EN_Pin;
  HAL_GPIO_Init(DCMI_PWR_EN_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PH14 PH12 PH9 PH11
                           PH10 */
  GPIO_InitStruct.Pin = GPIO_PIN_14|GPIO_PIN_12|GPIO_PIN_9|GPIO_PIN_11
                          |GPIO_PIN_10;
  /*Configure GPIO pin : ARDUINO_PWM_CS_D10_Pin */
  GPIO_InitStruct.Pin = ARDUINO_PWM_CS_D10_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF2_TIM5;
  HAL_GPIO_Init(ARDUINO_PWM_CS_D10_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : VCP_TX_Pin */
  GPIO_InitStruct.Pin = VCP_TX_Pin;
  HAL_GPIO_Init(VCP_TX_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : PA8 */
  GPIO_InitStruct.Pin = GPIO_PIN_8;
  GPIO_InitStruct.Alternate = GPIO_AF0_MCO;
  /*Configure GPIO pin : LCD_INT_Pin */
  GPIO_InitStruct.Pin = LCD_INT_Pin;
  HAL_GPIO_Init(LCD_INT_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : ARDUINO_RX_D0_Pin ARDUINO_TX_D1_Pin */
  GPIO_InitStruct.Pin = ARDUINO_RX_D0_Pin|ARDUINO_TX_D1_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF8_USART6;
  /*Configure GPIO pin : ULPI_NXT_Pin */
  GPIO_InitStruct.Pin = ULPI_NXT_Pin;
  HAL_GPIO_Init(ULPI_NXT_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : FMC_SDNME_Pin PH3 */
  GPIO_InitStruct.Pin = FMC_SDNME_Pin|GPIO_PIN_3;
  /*Configure GPIO pins : ARDUINO_D4_Pin ARDUINO_D2_Pin EXT_RST_Pin */
  GPIO_InitStruct.Pin = ARDUINO_D4_Pin|ARDUINO_D2_Pin|EXT_RST_Pin;
  /*Configure GPIO pins : ARDUINO_A4_Pin ARDUINO_A5_Pin ARDUINO_A1_Pin ARDUINO_A2_Pin
                           ARDUINO_A3_Pin */
  GPIO_InitStruct.Pin = ARDUINO_A4_Pin|ARDUINO_A5_Pin|ARDUINO_A1_Pin|ARDUINO_A2_Pin
                          |ARDUINO_A3_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  /*Configure GPIO pin : PC3 */
  /*Configure GPIO pins : ULPI_STP_Pin ULPI_DIR_Pin */
  GPIO_InitStruct.Pin = ULPI_STP_Pin|ULPI_DIR_Pin;
  /*Configure GPIO pins : RMII_MDC_Pin RMII_RXD0_Pin RMII_RXD1_Pin */
  GPIO_InitStruct.Pin = RMII_MDC_Pin|RMII_RXD0_Pin|RMII_RXD1_Pin;
  /*Configure GPIO pin : PB2 */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
  /*Configure GPIO pins : QSPI_D1_Pin QSPI_D3_Pin QSPI_D0_Pin */
  GPIO_InitStruct.Pin = QSPI_D1_Pin|QSPI_D3_Pin|QSPI_D0_Pin;
  /*Configure GPIO pin : RMII_RXER_Pin */
  GPIO_InitStruct.Pin = RMII_RXER_Pin;
  HAL_GPIO_Init(RMII_RXER_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : RMII_REF_CLK_Pin RMII_MDIO_Pin RMII_CRS_DV_Pin */
  GPIO_InitStruct.Pin = RMII_REF_CLK_Pin|RMII_MDIO_Pin|RMII_CRS_DV_Pin;
  /*Configure GPIO pin : ARDUINO_A0_Pin */
  GPIO_InitStruct.Pin = ARDUINO_A0_Pin;
  HAL_GPIO_Init(ARDUINO_A0_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PA4 PA6 */
  GPIO_InitStruct.Pin = GPIO_PIN_4|GPIO_PIN_6;
  /*Configure GPIO pins : LCD_SCL_Pin LCD_SDA_Pin */
  GPIO_InitStruct.Pin = LCD_SCL_Pin|LCD_SDA_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF4_I2C3;
  /*Configure GPIO pins : ULPI_CLK_Pin ULPI_D0_Pin */
  GPIO_InitStruct.Pin = ULPI_CLK_Pin|ULPI_D0_Pin;
  /*Configure GPIO pin : ARDUINO_PWM_D6_Pin */
  GPIO_InitStruct.Pin = ARDUINO_PWM_D6_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF9_TIM12;
  HAL_GPIO_Init(ARDUINO_PWM_D6_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : ARDUINO_MISO_D12_Pin ARDUINO_MOSI_PWM_D11_Pin */
  GPIO_InitStruct.Pin = ARDUINO_MISO_D12_Pin|ARDUINO_MOSI_PWM_D11_Pin;
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
