ethernet communication
Question asked by p.sowmya on Oct 10, 2015
Latest reply on Oct 10, 2015 by Clive One
Dear Sir/Madam
I am using modbus TCP/IP protocol using ethernet card , the issue is when ever i unplug the ethernet cable manually with out power off and reinsert the same the communication between the modbus and ethernet fails ,in order to solve that i need to stop and reconnect the modbus , if i reconnect  it will start working agin with our resetting the ethernet card,i kindly request you to give an solution for the above issue by considering this as highest priority,
regards
