STM32f3xx 8 bit SPI problem
Question asked by sari.mert on Jul 12, 2015
Latest reply on Jul 12, 2015 by sari.mert
Iadjusts8-bitSPIclock16palswithstm32cubemxbutwhatI seein theoscilloscopethis problemcould that be?
MCU STM32F302RCxx
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2015 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f3xx_hal.h"
/* USER CODE END Includes */
ADC_HandleTypeDef hadc1;
SPI_HandleTypeDef hspi3;
TIM_HandleTypeDef htim6;
UART_HandleTypeDef huart1;
UART_HandleTypeDef huart3;
/* USER CODE BEGIN PV */
#define KEY_OUT1_1      GPIOC->BSRRL = GPIO_BSRR_BS_4
#define KEY_OUT1_0      GPIOC->BSRRH = GPIO_BSRR_BS_4
#define KEY_OUT2_1      GPIOC->BSRRL = GPIO_BSRR_BS_5
#define KEY_OUT2_0      GPIOC->BSRRH = GPIO_BSRR_BS_5
#define KEY_OUT3_1      GPIOB->BSRRL = GPIO_BSRR_BS_0
#define KEY_OUT3_0      GPIOB->BSRRH = GPIO_BSRR_BS_0
#define KEY_OUT4_1      GPIOB->BSRRL = GPIO_BSRR_BS_1
#define KEY_OUT4_0      GPIOB->BSRRH = GPIO_BSRR_BS_1
#define SW_1            ((GPIOC->IDR & 0x0002)>>1)
unsigned char ms_data=0;
/* USER CODE END PV */
static void MX_ADC1_Init(void);
static void MX_SPI3_Init(void);
static void MX_TIM6_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_USART3_UART_Init(void);
/* USER CODE BEGIN PFP */
void delay_ms(unsigned int ms);
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_ADC1_Init();
  MX_SPI3_Init();
  MX_TIM6_Init();
  MX_USART1_UART_Init();
  MX_USART3_UART_Init();
  /* USER CODE BEGIN 2 */
    KEY_OUT1_0;
    KEY_OUT2_1;
    KEY_OUT3_1;
    KEY_OUT4_1;
    SPI3->CR1 &= ~SPI_CR1_SPE;          /* Disable SPI1 */
//  SPI3->CR2 |= SPI_CR2_DS_2 | SPI_CR2_DS_1 | SPI_CR2_DS_0; //0111: 8-bit for DS
    GPIOC->BSRRL = GPIO_BSRR_BS_13; delay_ms(1000); GPIOC->BSRRH = GPIO_BSRR_BS_13; delay_ms(1000);
    SPI3->CR1 |= SPI_CR1_SPE;
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
        if (SW_1==0)
            ms_data=0xAA;
            SPI3->DR = ms_data;
            while((SPI3->SR & SPI_SR_RXNE) != SPI_SR_RXNE){}
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1
                              |RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2);
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART3
                              |RCC_PERIPHCLK_ADC12;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInit.Usart3ClockSelection = RCC_USART3CLKSOURCE_PCLK1;
  PeriphClkInit.Adc12ClockSelection = RCC_ADC12PLLCLK_DIV1;
  HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
/* ADC1 init function */
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
  hadc1.Init.Resolution = ADC_RESOLUTION10b;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.EOCSelection = EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.Overrun = OVR_DATA_OVERWRITTEN;
  HAL_ADC_Init(&hadc1);
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = 1;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.SamplingTime = ADC_SAMPLETIME_2CYCLES_5;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  HAL_ADC_ConfigChannel(&hadc1, &sConfig);
/* SPI3 init function */
  hspi3.Instance = SPI3;
  hspi3.Init.Mode = SPI_MODE_MASTER;
  hspi3.Init.Direction = SPI_DIRECTION_2LINES;
  hspi3.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi3.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi3.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi3.Init.NSS = SPI_NSS_SOFT;
  hspi3.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_64;
  hspi3.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi3.Init.TIMode = SPI_TIMODE_DISABLED;
  hspi3.Init.CRCCalculation = SPI_CRCCALCULATION_ENABLED;
  hspi3.Init.CRCPolynomial = 50;
  hspi3.Init.CRCLength = SPI_CRC_LENGTH_8BIT;
  hspi3.Init.NSSPMode = SPI_NSS_PULSE_DISABLED;
  HAL_SPI_Init(&hspi3);
/* TIM6 init function */
  TIM_MasterConfigTypeDef sMasterConfig;
  htim6.Instance = TIM6;
  htim6.Init.Prescaler = 0;
  htim6.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim6.Init.Period = 359;
  HAL_TIM_Base_Init(&htim6);
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  HAL_TIMEx_MasterConfigSynchronization(&htim6, &sMasterConfig);
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED ;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  HAL_UART_Init(&huart1);
/* USART3 init function */
  huart3.Instance = USART3;
  huart3.Init.BaudRate = 38400;
  huart3.Init.WordLength = UART_WORDLENGTH_8B;
  huart3.Init.StopBits = UART_STOPBITS_1;
  huart3.Init.Parity = UART_PARITY_NONE;
  huart3.Init.Mode = UART_MODE_TX_RX;
  huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart3.Init.OverSampling = UART_OVERSAMPLING_16;
  huart3.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED ;
  huart3.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  HAL_UART_Init(&huart3);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  /* GPIO Ports Clock Enable */
  __GPIOC_CLK_ENABLE();
  __GPIOF_CLK_ENABLE();
  __GPIOA_CLK_ENABLE();
  __GPIOB_CLK_ENABLE();
  __GPIOD_CLK_ENABLE();
  /*Configure GPIO pins : PC13 PC14 PC4 PC5
                           PC6 PC8 PC9 PC10
                           PC11 PC12 */
  GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_4|GPIO_PIN_5
                          |GPIO_PIN_6|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10
                          |GPIO_PIN_11|GPIO_PIN_12;
  GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  /*Configure GPIO pins : PC15 PC1 PC2 PC3
                           PC7 */
  GPIO_InitStruct.Pin = GPIO_PIN_15|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_7;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  /*Configure GPIO pins : PA0 PA1 PA2 PA3
                           PA4 PA5 PA6 PA7
                           PA8 PA11 PA15 */
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
                          |GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7
                          |GPIO_PIN_8|GPIO_PIN_11|GPIO_PIN_15;
  /*Configure GPIO pins : PB0 PB1 PB15 PB8
                           PB9 */
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_15|GPIO_PIN_8
                          |GPIO_PIN_9;
  /*Configure GPIO pins : PB2 PB12 PB13 PB14
                           PB6 PB7 */
  GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14
                          |GPIO_PIN_6|GPIO_PIN_7;
  /*Configure GPIO pin : PA12 */
  GPIO_InitStruct.Pin = GPIO_PIN_12;
  /*Configure GPIO pin : PD2 */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
    unsigned int i, j;
    for(i=0; i<ms; i++)
        for(j=0; j<3598; j++)
            __nop();
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
