IAR ilinkarm unreasonable placement failure [Lp011]
Question asked by kirem on Jul 6, 2015
I'm having an issue allocating space for a heap.
The version of the linker I'm using is 7.40.3.8902
Here's a extract from the linker icf file.
define symbol RAM_HEAP_start         = 0x20018000;
define symbol RAM_HEAP_end           = 0x2001BFFF;
define symbol __ICFEDIT_size_heap__   = 0x2000;
define region RAM_HEAP_region   = mem:[from RAM_HEAP_start    to RAM_HEAP_end];
define block HEAP               with alignment = 8, size = __ICFEDIT_size_heap__   { };
place in RAM_HEAP_region        { block HEAP };
I get the following error:
Error[Lp011]: section placement failed
 unable to allocate space for sections/blocks with a total estimated minimum size of  0x2000 bytes (max align 0x8) in <[0x20018000-0x2001bfff]> (total uncommitted space  0x0).
RAM_HEAP_region should define a space for 0x4000 bytes. __ICFEDIT_size_heap__ = 0x2000 which should fit quite nicely. reducing the number to 0x1d18 finally links.
Anyone have any ideas what I might be doing wrong?
Thanks, Kirem
