STM32F3 & SysTick_Handler(void) :(
Question asked by mondher.dellagi on May 13, 2015
Latest reply on May 13, 2015 by mondher.dellagi
hi
when i compli file stm32f3x0.t, i get this error :stm32f30x_it.c(152): error:  #268: declaration may not appear after executable statement in block
this my code :
  * @file    stm32f30x_it.c
  * @author  MCD Application Team
  * @version V1.1.0
  * @date    20-September-2012
  * @brief   Main Interrupt Service Routines.
  *          This file provides template for all exceptions handler and
  *          peripherals interrupt service routine.
  * @attention
  * <h2><center>&copy; COPYRIGHT 2012 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
#include "stm32f30x_it.h"
#include <stm32f30x_rcc.h>
#include <stm32f30x.h>
/** @addtogroup STM32F3-Discovery_Demo
/*            Cortex-M4 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles Memory Manage exception.
  * @param  None
  * @retval None
void MemManage_Handler(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
  * @brief  This function handles Bus Fault exception.
  * @param  None
  * @retval None
void BusFault_Handler(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
  * @brief  This function handles Usage Fault exception.
  * @param  None
  * @retval None
void UsageFault_Handler(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles Debug Monitor exception.
  * @param  None
  * @retval None
void DebugMon_Handler(void)
  * @brief  This function handles PendSVC exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
     // in board.c
     volatile extern uint64_t SysTickCount;
     SysTickCount++;
     // in board.c
     volatile extern uint32_t TimingDelayCounter;
     if (TimingDelayCounter != 0x00)
          TimingDelayCounter--;
/*                 STM32F30x Peripherals Interrupt Handlers                   */
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_stm32f30x.s).                                            */
  * @brief  This function handles EXTI0_IRQ Handler.
  * @param  None
  * @retval None
void EXTI0_IRQHandler(void)
     extern void KeyPressGpioCheck(void);
     KeyPressGpioCheck();
  * @brief  This function handles PPP interrupt request.
  * @param  None
  * @retval None
/*void PPP_IRQHandler(void)
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
