SPWF01SA saving html file
Question asked by Lori B. on Oct 3, 2014
Latest reply on Nov 20, 2014 by Gerardo Gallucci
Hi! I'm using a SPWF01SA with daughter-board and USB dongle.
I'm comunicating using AT commands, through Docklight.
I'm trying to create a new HTML file and everything works fine using the proper commands. I create the file, then I write the HTML code using the "append" command and finally I save the current settings.
After that I am able to print the file correctly and event to access it through Wifi connection from my host.
The problem is that after resetting the module or simply disconnecting it from power, the file disappears. What is the problem with the module? Should I do something else to save the file I wrote to non-volatile memory or something like that? Thanks!
