32F429IDISCOVERY LCD ILI9341 driver
Question asked by machala.petr on Mar 19, 2015
Latest reply on Mar 26, 2015 by machala.petr
I would like to ask if anyone has successfully changed the setting of the ILI9341 driver to little endian...I have data in this format but in default I have to send over SPI high byte first and low byte after that...I need it to be the other way around...
From data sheet http://www.newhavendisplay.com/app_notes/ILI9341.pdf I am convinced that the configuration should be something like this but it doesn't work...thanks for help...
#define ILI9341_RGB_INTERFACE         0xB0
#define ILI9341_PIXEL_FORMAT         0x3A
#define ILI9341_INTERFACE               0xF6
LCD_ILI9341_SendCommand(ILI9341_PIXEL_FORMAT);
LCD_ILI9341_SendData(0x55);
LCD_ILI9341_SendCommand(ILI9341_INTERFACE);
LCD_ILI9341_SendData(0x01);
LCD_ILI9341_SendData(0x00);
LCD_ILI9341_SendData(0x20);
LCD_ILI9341_SendCommand(ILI9341_RGB_INTERFACE);
LCD_ILI9341_SendData(0x40);
