STM32F429 Timer1 + DMA2 + SPI1
Question asked by dirkson on Jan 28, 2015
Latest reply on Jan 31, 2015 by dirkson
is the following possible?
Timer1 is in capture/compare mode. If an compare event is generated => start DMA2
DMA2 copy 2bytes in the data register of SPI1.
SPI1 send the 2bytes
I have try it, but I get no CLK signal. The only one is the OCx signal, that is ok. If Iwrite
SPI_I2S_SendData(SPI1, 0xAAFF);
 without the timer1, I get the signal.
Can you help me please?
Best regards,
Dirk
// init Timer1
    TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    TIM_TimeBaseStructure.TIM_Period = 8000-1;
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
    TIM_OCInitTypeDef TIM_OCInitStructure;
    TIM_OCInitStructure.TIM_OCMode            = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState        = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState    = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_Pulse            = 1000-1;
    TIM_OCInitStructure.TIM_OCPolarity        = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OCNPolarity        = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState        = TIM_OCIdleState_Reset;
    TIM_OCInitStructure.TIM_OCNIdleState    = TIM_OCNIdleState_Reset;
    TIM_OC1Init( TIM1, &TIM_OCInitStructure );
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    TIM_ITConfig(TIM1, TIM_IT_CC1, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_TIM10_IRQn;
    TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE);
    TIM_SelectCCDMA(TIM1, ENABLE);
    TIM_DMACmd(TIM1, TIM_DMA_CC1, ENABLE);
// init DMA
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
    DMA_InitStructure.DMA_Channel                 = DMA_Channel_6;
    DMA_InitStructure.DMA_PeripheralBaseAddr     = (uint32_t) & (SPI1->DR);
    DMA_InitStructure.DMA_Memory0BaseAddr        = (uint32_t) AdcBufferSend.begin_p;
    DMA_InitStructure.DMA_DIR                    = DMA_DIR_MemoryToPeripheral;
    DMA_InitStructure.DMA_BufferSize            = 1;
    DMA_InitStructure.DMA_PeripheralInc            = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc                = DMA_MemoryInc_Disable;
    DMA_InitStructure.DMA_PeripheralDataSize    = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize        = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode                    = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority                = DMA_Priority_VeryHigh;
    DMA_InitStructure.DMA_FIFOMode                = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold            = DMA_FIFOThreshold_Full;
    DMA_InitStructure.DMA_MemoryBurst            = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst        = DMA_PeripheralBurst_Single;
    DMA_Init(DMA2_Stream5, &DMA_InitStructure);
    SPI_I2S_DMACmd( SPI1, SPI_I2S_DMAReq_Tx, ENABLE );
// init spi
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
    SPI_I2S_DeInit(SPI1);
    SPI_InitTypeDef SPI_InitStructure;
    SPI_InitStructure.SPI_Direction         = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode                 = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize            = SPI_DataSize_16b;
    SPI_InitStructure.SPI_CPOL                = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA                = SPI_CPHA_1Edge;
    SPI_InitStructure.SPI_NSS                = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = spiClockFrequency;
    SPI_InitStructure.SPI_FirstBit            = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial        = 0;
    SPI_Init(SPI1, &SPI_InitStructure );
//start
    DMA_Cmd( DMA2_Stream0,ENABLE );
    DMA_Cmd( DMA2_Stream5,ENABLE );
    SPI_Cmd( SPI1, ENABLE );
    TIM_Cmd(TIM1, ENABLE);
