Bare metal java with STM32 cube
Question asked by wis on Feb 21, 2014
Latest reply on Feb 24, 2014 by Amel N
I am trying to evaluate/build a bare metal java application for my STM3240g eval board as described in the application note I found at http://www.stm32java.com/portal/?q=resources/application-notes.
The tutorial in the application notes says that the standard peripherals library is a prerequesite for building the sample project. Obviously ST decided to no longer deliver the standard peripherals lib per device but rather in a "cube" which contains all libaries etc for different devices.
So far so good, but when trying to build the samples i recognised that ST significantly changed theirs APIs not only regarding some includes but also renamed files and changed directory structures.
What do you recommend to be able to build a java app as described in the app notes mentioned above?
Thanks for advice!
Stefan
