Stm32f407 Can bus problem
Question asked by cinar.Abdullah on Nov 4, 2014
Latest reply on Dec 4, 2014 by ABCD
Hi all,
I am working on a project with stm32f407 and i want to communicate to stm32f407 boards with each other using can communication. I am using sn65hvd transceiver and i made this scheme :
i am using 2 circuit like this. Their CANH and CANL are connected other CANH and CANL. i think there is no problem with transceiver part. Probably i am doing something wrong with the code. Here is my code, can anyone tell me where am i doing wrong?
I am using can1 tx pb9, and can1 rx pb8. First stm32's tx and rx go receiver and 2 transceiver's canh and canl are common; then output of other transceiver (tx and rx) go other stm32's pb8 and pb9.
Here is my code of receiver stm32
#include "can_control.h"
#include "stm32f4_discovery.h"
#include <stdint.h>
#define CAN_CLK                    RCC_APB1Periph_CAN
#define CAN_RX_PIN                 GPIO_Pin_8
#define CAN_TX_PIN                 GPIO_Pin_9
#define CAN_GPIO_PORT              GPIOB
#define CAN_GPIO_CLK               RCC_AHBPeriph_GPIOB
#define CAN_AF_PORT                GPIO_AF_4
#define CAN_RX_SOURCE              GPIO_PinSource8
#define CAN_TX_SOURCE              GPIO_PinSource9
CanTxMsg TxMessage;
CanRxMsg RxMessage;
static
void CAN_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  NVIC_InitTypeDef  NVIC_InitStructure;
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  /* CAN GPIOs configuration **************************************************/
  /* Enable GPIO clock */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  /* Connect CAN pins to AF7 */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_CAN1);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_CAN1);
  /* Configure CAN RX and TX pins */
  GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  GPIO_InitStructure.GPIO_Pin = CAN_TX_PIN;
  /* NVIC configuration *******************************************************/
  NVIC_InitStructure.NVIC_IRQChannel = CAN1_TX_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
  /* CAN configuration ********************************************************/
  /* Enable CAN clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = ENABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = ENABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  /* CAN Baudrate = 500kbps (CAN clocked at 48 MHz) */
  CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
  CAN_InitStructure.CAN_Prescaler = 16;
  CAN_Init(CAN1, &CAN_InitStructure);
  // 48Mhz / ( 8 * ( 1 + 6 + 5) ) = 500Kbps
  // 48Mhz / 96
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* transmit */
  TxMessage.StdId = 0x321;
  TxMessage.ExtId = 0x11;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 8;
  /* Enable FIFO 0 message pending Interrupt */
  CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
void DelayInt(void)
    volatile int i = 1000000;
    while(i--);
uint8_t CanSendRes = 0;
void CanControlInit(void)
    uint8_t TransmitMailbox = 0;
    CAN_Config();
    CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
Then here is my code of transmitter Stm32
#include <stdint.h>
CanTxMsg TxMessage;
CanRxMsg RxMessage;
static
  NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
  CAN_DeInit(CAN1);
  /* CAN cell init */
  // 48Mhz / 96
  /* transmit */
  TxMessage.DLC = 8;
void DelayInt(void)
    while(i--);
  uint32_t i = 0;
    CAN_Config();
      TxMessage.DLC = 8;
      TxMessage.Data[0] = 0xFF;
      TxMessage.Data[1] = 0xFF;
      TxMessage.Data[2] = 0xFF;
      TxMessage.Data[3] = 0xFF;
      TxMessage.Data[4] = 0xAA;
      TxMessage.Data[5] = 0xBB;
      TxMessage.Data[6] = 0xCB;
      TxMessage.Data[7] = 0x24;
    while(1)
      CAN_Transmit(CAN1, &TxMessage);
When i look at my pb9( tx pin) at scop, i cant see anything meaningfull, i think its just noise. i guess i'm doing something so wrong and cant see it, please help me about my problem i will be so appreciated.
(Sorry about my bad english and this long writing :) )
