TIM PWM input Example
Question asked by chechio.cesare on Jun 23, 2014
Latest reply on Jul 2, 2014 by Clive One
How can I modify this example to read pwm signals with a frequency of 40Hz?
#include "stm32f4_discovery.h"
#include "stm32f4xx_it.h"
/** @addtogroup STM32F4_Discovery_Peripheral_Examples
/** @addtogroup TIM_PWM_Input
TIM_ICInitTypeDef  TIM_ICInitStructure;
void TIM_Config(void);
  * @brief  Main program
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f4xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f4xx.c file
  /* TIM Configuration */
  TIM_Config();
  /* TIM4 configuration: PWM Input mode ------------------------
     The external signal is connected to TIM4 CH2 pin (PB.07),
     The Rising edge is used as active edge,
     The TIM4 CCR2 is used to compute the frequency value
     The TIM4 CCR1 is used to compute the duty cycle value
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(TIM4, &TIM_ICInitStructure);
  /* Select the TIM4 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM4, TIM_TS_TI2FP2);
  /* Select the slave Mode: Reset Mode */
  TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(TIM4,TIM_MasterSlaveMode_Enable);
  /* TIM enable counter */
  TIM_Cmd(TIM4, ENABLE);
  /* Enable the CC2 Interrupt Request */
  TIM_ITConfig(TIM4, TIM_IT_CC2, ENABLE);
  uint16_t duty = getFrequency();
  uint32_t freq = getDuyCycle();
  while (1);
  * @brief  Configure the TIM4 Pins.
  * @param  None
  * @retval None
  /* TIM4 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  /* GPIOB clock enable */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  /* TIM4 chennel2 configuration : PB.07 */
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  /* Connect TIM pin to AF2 */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_TIM4);
  /* Enable the TIM4 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
