STM32CubeMX NOT CREATING PROJECTS
Question asked by bassett.david_c on Jun 1, 2014
Latest reply on Sep 26, 2014 by STM32Cube-T
Hi All,
I am trying to use the Cube software to generate a baseline project code. The config and manage code level is 4.2.0, and the firmware level is 1.1.0. When I step through configuring for the 429 and hit code config, I get no projects created. I have installed the latest Java as per one post. I have windows7 64 bit on a standard Toshiba laptop.
The cube software has created projects once or twice, but never consistently. I have uninstalled and reinstalled the Cube software and run as admin and not as admin with no consistent results. this is getting very frustrating to work with.
The software will go as far as making an INC and SRC directory and put a tmp file into src directory, but that is all. I have checked copy all and checking all boxes in the generated file section of the code generator section of the project settings. I have attached the ioc file in case there is any info in here which might help.
Does anybody out there have any suggestions as to how to make this work for me?
Dave Bassett
