problem with timers cascade
Question asked by montagnani.giovanni_ on May 18, 2014
Latest reply on May 18, 2014 by montagnani.giovanni_
hello everybody, i've a problem with cascading 3 timers
i want to set TIM1 as a master, TIM2 as a slave (gated) and TIM3 as a slave of TIM1.
even if i use hal library i think the problem in my cade is simple!
i wrote this code, please help me :
/* TIM1 init function */
void MX_TIM1_Init(void)
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_OC_InitTypeDef sConfigOC;
  TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim1.Instance = TIM1;
  htim1.Init.Prescaler = 0;
  htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim1.Init.Period = 100;
  htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim1.Init.RepetitionCounter = 0;
  HAL_TIM_Base_Init(&htim1);
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig);
  HAL_TIM_PWM_Init(&htim1);
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = 10;
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1);
  sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig);
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_OC1REF;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_ENABLE;
  HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig);
/* TIM2 init function */
void MX_TIM2_Init(void)
  TIM_SlaveConfigTypeDef sSlaveConfig;
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 0;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 100;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  HAL_TIM_Base_Init(&htim2);
  HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig);
  HAL_TIM_PWM_Init(&htim2);
  sConfigOC.Pulse = 0;
  HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_1);
  sSlaveConfig.SlaveMode = TIM_SLAVEMODE_GATED;
  sSlaveConfig.InputTrigger = TIM_TS_ITR0;
  HAL_TIM_SlaveConfigSynchronization(&htim2, &sSlaveConfig);
  HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig);
/* TIM4 init function */
void MX_TIM4_Init(void)
  htim4.Instance = TIM4;
  htim4.Init.Prescaler = 1;
  htim4.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim4.Init.Period = 100;
  htim4.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  HAL_TIM_Base_Init(&htim4);
  HAL_TIM_ConfigClockSource(&htim4, &sClockSourceConfig);
  HAL_TIM_PWM_Init(&htim4);
  HAL_TIM_OnePulse_Init(&htim4, TIM_OPMODE_SINGLE);
  sConfigOC.Pulse = 50;
  HAL_TIM_PWM_ConfigChannel(&htim4, &sConfigOC, TIM_CHANNEL_1);
  sSlaveConfig.InputTrigger = TIM_TS_ITR1;
  HAL_TIM_SlaveConfigSynchronization(&htim4, &sSlaveConfig);
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  HAL_TIMEx_MasterConfigSynchronization(&htim4, &sMasterConfig);
the problem is that i see tim4 ch1 working (led4 is on) even if i write
//HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_1); //HAL_TIM_PWM_Start(&htim2,TIM_CHANNEL_1);
              HAL_TIM_PWM_Start(&htim4,TIM_CHANNEL_1);
so the first two pwm are not working, why i see an output?
thank you so much for your time
Gio
