STMf030 USART
Question asked by das.sanjib on Apr 5, 2014
Latest reply on Jul 12, 2014 by xinxin.xinxin
I have written a code for stmf030 USART code Half duplex . I have configured USART1 and USAR2 of stm32f030 where Usart1 will sent data to usart 2 and usart2 data will send data to usart 1 . for checking purpose I am blinkig the LED after comparing TransferStatus1 and TransferStatus2. (should blink after connecting pin PA2(usart2_tx) and PB6 (USart1_tX)
The same code is working for stm32f407 . I have configured the same working code for stm32f030. but it's not working what mistake I am doing please look at the given code below
  * @file    USART/HalfDuplex/main.c
  * @author  MCD Application Team
  * @version V3.4.0
  * @date    10/15/2010
  * @brief   Main program body
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2010 STMicroelectronics</center></h2>
#include <stm32f0xx.h>
#include "stm32f0xx_adc.h"
#include "stm32f0xx_gpio.h"
#include "stm32f0xx_rcc.h"
#include "stm32f0xx_usart.h"
#include <stm32f0xx_syscfg.h>
//#include "stm32f0xx_discovery.h"
#include "stdio.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup USART_HalfDuplex
typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus;
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define TxBufferSize2   (countof(TxBuffer2) - 1)
#define countof(a)   (sizeof(a) / sizeof(*(a)))
USART_InitTypeDef USART_InitStructure;
uint8_t TxBuffer1[] = "USART Half Duplex: USARTy -> USARTz using HalfDuplex mode";
uint8_t TxBuffer2[] = "USART Half Duplex: USARTz -> USARTy using HalfDuplex mode";
uint8_t RxBuffer1[TxBufferSize2];
uint8_t RxBuffer2[TxBufferSize1];
uint32_t NbrOfDataToRead1 = TxBufferSize2;
uint32_t NbrOfDataToRead2 = TxBufferSize1;
uint8_t TxCounter1 = 0, RxCounter1 = 0;
uint8_t TxCounter2 = 0, RxCounter2 = 0;
volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = FAILED;
void RCC_Configuration(void);
void GPIO_Configuration(void);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
     //STM_EVAL_LEDInit(LED1);
  /* System Clocks Configuration */
  RCC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
/* USARTy and USARTz configuration -------------------------------------------*/
  /* USARTy and USARTz configured as follow:
        - BaudRate = 230400 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  /* Configure USARTy */
  USART_Init(USART1, &USART_InitStructure);
  /* Configure USARTz */
  USART_Init(USART2, &USART_InitStructure);
  /* Enable the USARTy */
  USART_Cmd(USART1, ENABLE);
  /* Enable the USARTz */
  USART_Cmd(USART2, ENABLE);
  /* Enable USARTy Half Duplex Mode*/
  USART_HalfDuplexCmd(USART1, ENABLE);
  /* Enable USARTz Half Duplex Mode*/
  USART_HalfDuplexCmd(USART2, ENABLE);
  while(NbrOfDataToRead2--)
    /* Wait until end of transmit */
    while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET)
    /* Write one byte in the USARTy Transmit Data Register */
    USART_SendData(USART1, TxBuffer1[TxCounter1++]);
    /* Wait the byte is entirtly received by USARTz */
    while(USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET)
    /* Store the received byte in the RxBuffer2 */
    RxBuffer2[RxCounter2++] = USART_ReceiveData(USART2);
  /* Clear the USARTy Data Register */
  USART_ReceiveData(USART1);
  while(NbrOfDataToRead1--)
    while(USART_GetFlagStatus(USART2, USART_FLAG_TXE)== RESET)
    /* Write one byte in the USARTz Transmit Data Register */
    USART_SendData(USART2, TxBuffer2[TxCounter2++]);
    /* Wait the byte is entirtly received by USARTy */
    while(USART_GetFlagStatus(USART1,USART_FLAG_RXNE) == RESET)
    /* Store the received byte in the RxBuffer1 */
    RxBuffer1[RxCounter1++] = USART_ReceiveData(USART1);
  /* Check the received data with the send ones */
  TransferStatus1 = Buffercmp(TxBuffer1, RxBuffer2, TxBufferSize1);
  /* TransferStatus = PASSED, if the data transmitted from USARTy and
     received by USARTz are the same */
  /* TransferStatus = FAILED, if the data transmitted from USARTy and
     received by USARTz are different */
  TransferStatus2 = Buffercmp(TxBuffer2, RxBuffer1, TxBufferSize2);
  if( TransferStatus1== TransferStatus2)
      GPIO_SetBits(GPIOC, (GPIO_Pin_8 | GPIO_Pin_9));
  /* TransferStatus = PASSED, if the data transmitted from USARTz and
     received by USARTy are the same */
  /* TransferStatus = FAILED, if the data transmitted from USARTz and
     received by USARTy are different */
  while (1)
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
     RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
    //RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
  /* Enable GPIO clock */
 //RCC_APB2PeriphClockCmd(USARTy_GPIO_CLK | USARTz_GPIO_CLK | RCC_APB2Periph_AFIO, ENABLE);
     * for pin pb6 tx Usart 1
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
       * for pin pd5 tx Usart 2
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
#ifndef USE_STM3210C_EVAL
  /* Enable USART1 Clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  //RCC_APB2PeriphClockCmd(USARTy_CLK, ENABLE);
#else
  /* Enable USARTy Clock */
  RCC_APB1PeriphClockCmd(USARTy_CLK, ENABLE);
#endif
  /* Enable USART2 Clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
 // RCC_APB1PeriphClockCmd(USARTz_CLK, ENABLE);
  * @brief  Configures the different GPIO ports.
  * @param  None
  * @retval None
#ifdef USE_STM3210C_EVAL
  /* Enable the USART3 Pins Software Remapping */
  GPIO_PinRemapConfig(GPIO_PartialRemap_USART3, ENABLE);
  /* Enable the USART2 Pins Software Remapping */
  GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
#elif defined(USE_STM3210B_EVAL) || defined(USE_STM32100B_EVAL)
#endif
  /* Configure PC8 and PC9 in output pushpull mode */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  /* Configure USART1 Tx as alternate function open-drain */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF;
  /* Configure USART2 Tx as alternate function open-drain */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource6,GPIO_AF_1); //
      GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1);
  * @brief  Compares two buffers.
  * @param  pBuffer1, pBuffer2: buffers to be compared.
  * @param  BufferLength: buffer's length
  * @retval PASSED: pBuffer1 identical to pBuffer2
  *   FAILED: pBuffer1 differs from pBuffer2
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
