LSM303DLHC accelerometer Data not repeatable
Question asked by Manish on Mar 27, 2014
Latest reply on Mar 27, 2014 by fm
Hello
     I am working with STM32f3-Discovery Board with LSM303DLHC sensor chip Programming. I am using GNU too chain for ARM on ubuntu 13.10 platform.
I am trying to read data From Accelerometer and magnetometer .
I have read data from X ,Y Z axes of both sensor many times repeatably .
Magnetometer data repeatable But Accelerometer data is not  repeatable.
I have Done following Initialization and Configuration
 I have interface  LSM303DLHC using I2C and STM32F3 Peripheral Driver Library for I2C
            1.Accelerometer I2C address
                #define ACC_I2C_ADDRESS    0x32
            2.Accelerometer Initialization
             I)Control register 1 (LSM303DLHC_CTRL_REG1_A)
               i)  Power_Mode            ->  Normal mode
               ii) AccOutput_DataRate ->  50Hz
               iii)Axes_Enable        ->  all axes enable
              II)Control register 4 (LSM303DLHC_CTRL_REG4_A)
                i) Output register Data Update ->  BlockUpdate_Continous
                ii) Endianness                   ->  Little Endian
                iii)AccFull_Scale              ->  2g
                iv)High_Resolution             ->  High Resolution enabled
I'm Not getting why data is not repeatable .I am mentioning as well as attaching Source files related to that.Please help me regarding that.
..............................................main.c..................................................
#define ABS(x)         (x < 0) ? (-x) : x
#define L3G_Sensitivity_250dps     (float)   114.285f         /*!< gyroscope sensitivity with 250 dps full scale [LSB/dps] */
#define L3G_Sensitivity_500dps     (float)    57.1429f        /*!< gyroscope sensitivity with 500 dps full scale [LSB/dps] */
#define L3G_Sensitivity_2000dps    (float)    14.285f           /*!< gyroscope sensitivity with 2000 dps full scale [LSB/dps] */
#define PI                         (float)     3.14159265f
#define LSM_Acc_Sensitivity_2g     (float)     1.0f            /*!< accelerometer sensitivity with 2 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_4g     (float)     0.5f            /*!< accelerometer sensitivity with 4 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_8g     (float)     0.25f           /*!< accelerometer sensitivity with 8 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_16g    (float)     0.0834f         /*!< accelerometer sensitivity with 12 g full scale [LSB/mg] */
  RCC_ClocksTypeDef RCC_Clocks;
__IO uint32_t TimingDelay = 0;
__IO uint32_t UserButtonPressed = 0;
__IO float HeadingValue = 0.0f;
float MagBuffer[3] = {0.0f}, AccBuffer[3] = {0.0f}, Buffer[3] = {0.0f};
uint8_t Xval, Yval = 0x00;
__IO uint8_t DataReady = 0;
__IO uint8_t PrevXferComplete = 1;
__IO uint32_t USBConnectTimeOut = 100;
float fNormAcc,fSinRoll,fCosRoll,fSinPitch,fCosPitch = 0.0f, RollAng = 0.0f, PitchAng = 0.0f;
float fTiltedX,fTiltedY = 0.0f;
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  uint8_t i = 0;
  /* SysTick end of count event each 10ms */
  RCC_GetClocksFreq(&RCC_Clocks);
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
  /* Initialize LEDs and User Button available on STM32F3-Discovery board */
  STM_EVAL_LEDInit(LED3);
  STM_EVAL_LEDInit(LED4);
  STM_EVAL_LEDInit(LED5);
  STM_EVAL_LEDInit(LED6);
  STM_EVAL_LEDInit(LED7);
  STM_EVAL_LEDInit(LED8);
  STM_EVAL_LEDInit(LED9);
  STM_EVAL_LEDInit(LED10);
  STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_EXTI);
  /* Configure the USB */
  //Demo_USB();
  /* Reset UserButton_Pressed variable */
  UserButtonPressed = 0x00;
  /* Infinite loop */
  while (1)
    /* LEDs Off */
    STM_EVAL_LEDOff(LED3);
    STM_EVAL_LEDOff(LED6);
    STM_EVAL_LEDOff(LED7);
    STM_EVAL_LEDOff(LED4);
    STM_EVAL_LEDOff(LED10);
    STM_EVAL_LEDOff(LED8);
    STM_EVAL_LEDOff(LED9);
    STM_EVAL_LEDOff(LED5);
    /* Waiting User Button is pressed */
    while (UserButtonPressed == 0x00)
      /* Toggle LD3 */
      STM_EVAL_LEDToggle(LED3);
      /* Insert 50 ms delay */
      Delay(5);
      /* Toggle LD5 */
      STM_EVAL_LEDToggle(LED5);
      Delay(5);
      /* Toggle LD7 */
      STM_EVAL_LEDToggle(LED7);
      Delay(5);
      /* Toggle LD9 */
      STM_EVAL_LEDToggle(LED9);
      Delay(5);
      /* Toggle LD10 */
      STM_EVAL_LEDToggle(LED10);
      Delay(5);
      /* Toggle LD8 */
      STM_EVAL_LEDToggle(LED8);
      Delay(5);
      /* Toggle LD6 */
      STM_EVAL_LEDToggle(LED6);
      Delay(5);
      /* Toggle LD4 */
      STM_EVAL_LEDToggle(LED4);
      Delay(5);
    DataReady = 0x00;
    /* All LEDs Off */
    /* Demo Gyroscope */
    Demo_GyroConfig();
    while (UserButtonPressed == 0x01)
      /* Wait for data ready */
      while(DataReady != 0x05)
      DataReady = 0x00;
      /* LEDs Off */
      /* Read Gyro Angular data */
      Demo_GyroReadAngRate(Buffer);
      /* Update autoreload and capture compare registers value*/
      Xval = ABS((int8_t)(Buffer[0]));
      Yval = ABS((int8_t)(Buffer[1]));
      if ( Xval>Yval)
        if ((int8_t)Buffer[0] > 5.0f)
          /* LD10 On */
          STM_EVAL_LEDOn(LED10);
        if ((int8_t)Buffer[0] < -5.0f)
          /* LD3 On */
          STM_EVAL_LEDOn(LED3);
      else
        if ((int8_t)Buffer[1] < -5.0f)
          /* LD6 on */
          STM_EVAL_LEDOn(LED6);
        if ((int8_t)Buffer[1] > 5.0f)
          /* LD7 On */
          STM_EVAL_LEDOn(LED7);
    DataReady = 0x00;
    /* LEDs Off */
    /* Demo Compass */
    Demo_CompassConfig();
    while (UserButtonPressed == 0x02)
      while(DataReady !=0x05)
      DataReady = 0x00;
      /* Read Compass data */
      Demo_CompassReadMag(MagBuffer);
      Demo_CompassReadAcc(AccBuffer);
      for(i=0;i<3;i++)
        AccBuffer[i] /= 100.0f;
      fNormAcc = sqrt((AccBuffer[0]*AccBuffer[0])+(AccBuffer[1]*AccBuffer[1])+(AccBuffer[2]*AccBuffer[2]));
      fSinRoll = -AccBuffer[1]/fNormAcc;
      fCosRoll = sqrt(1.0-(fSinRoll * fSinRoll));
      fSinPitch = AccBuffer[0]/fNormAcc;
      fCosPitch = sqrt(1.0-(fSinPitch * fSinPitch));
     if ( fSinRoll >0)
       if (fCosRoll>0)
         RollAng = acos(fCosRoll)*180/PI;
       else
         RollAng = acos(fCosRoll)*180/PI + 180;
     else
       if (fCosRoll>0)
         RollAng = acos(fCosRoll)*180/PI + 360;
       else
      if ( fSinPitch >0)
       if (fCosPitch>0)
            PitchAng = acos(fCosPitch)*180/PI;
       else
          PitchAng = acos(fCosPitch)*180/PI + 180;
     else
       if (fCosPitch>0)
            PitchAng = acos(fCosPitch)*180/PI + 360;
       else
      if (RollAng >=360)
        RollAng = RollAng - 360;
      if (PitchAng >=360)
        PitchAng = PitchAng - 360;
      fTiltedX = MagBuffer[0]*fCosPitch+MagBuffer[2]*fSinPitch;
      fTiltedY = MagBuffer[0]*fSinRoll*fSinPitch+MagBuffer[1]*fCosRoll-MagBuffer[1]*fSinRoll*fCosPitch;
      HeadingValue = (float) ((atan2f((float)fTiltedY,(float)fTiltedX))*180)/PI;
      if (HeadingValue < 0)
        HeadingValue = HeadingValue + 360;
      if ((RollAng <= 40.0f) && (PitchAng <= 40.0f))
        if (((HeadingValue < 25.0f)&&(HeadingValue >= 0.0f))||((HeadingValue >=340.0f)&&(HeadingValue <= 360.0f)))
        else  if ((HeadingValue <70.0f)&&(HeadingValue >= 25.0f))
          STM_EVAL_LEDOn(LED9);
        else  if ((HeadingValue < 115.0f)&&(HeadingValue >= 70.0f))
        else  if ((HeadingValue <160.0f)&&(HeadingValue >= 115.0f))
          STM_EVAL_LEDOn(LED5);
        else  if ((HeadingValue <205.0f)&&(HeadingValue >= 160.0f))
        else  if ((HeadingValue <250.0f)&&(HeadingValue >= 205.0f))
          STM_EVAL_LEDOn(LED4);
        else  if ((HeadingValue < 295.0f)&&(HeadingValue >= 250.0f))
        else  if ((HeadingValue < 340.0f)&&(HeadingValue >= 295.0f))
          STM_EVAL_LEDOn(LED8);
      else
        /* Toggle All LEDs */
        /* Delay 50ms */
        Delay(5);
  * @brief  Configure the USB.
  * @param  None
  * @retval None
void Demo_USB (void)
  Set_System();
  Set_USBClock();
  USB_Interrupts_Config();
  USB_Init();
  while ((bDeviceState != CONFIGURED)&&(USBConnectTimeOut != 0))
  * @brief  Configure the Mems to gyroscope application.
  * @param  None
  * @retval None
void Demo_GyroConfig(void)
  L3GD20_InitTypeDef L3GD20_InitStructure;
  L3GD20_FilterConfigTypeDef L3GD20_FilterStructure;
  /* Configure Mems L3GD20 */
  L3GD20_InitStructure.Power_Mode = L3GD20_MODE_ACTIVE;
  L3GD20_InitStructure.Output_DataRate = L3GD20_OUTPUT_DATARATE_1;
  L3GD20_InitStructure.Axes_Enable = L3GD20_AXES_ENABLE;
  L3GD20_InitStructure.Band_Width = L3GD20_BANDWIDTH_4;
  L3GD20_InitStructure.BlockData_Update = L3GD20_BlockDataUpdate_Continous;
  L3GD20_InitStructure.Endianness = L3GD20_BLE_LSB;
  L3GD20_InitStructure.Full_Scale = L3GD20_FULLSCALE_500;
  L3GD20_Init(&L3GD20_InitStructure);
  L3GD20_FilterStructure.HighPassFilter_Mode_Selection =L3GD20_HPM_NORMAL_MODE_RES;
  L3GD20_FilterStructure.HighPassFilter_CutOff_Frequency = L3GD20_HPFCF_0;
  L3GD20_FilterConfig(&L3GD20_FilterStructure) ;
  L3GD20_FilterCmd(L3GD20_HIGHPASSFILTER_ENABLE);
  * @brief  Calculate the angular Data rate Gyroscope.
  * @param  pfData : Data out pointer
  * @retval None
void Demo_GyroReadAngRate (float* pfData)
  uint8_t tmpbuffer[6] ={0};
  int16_t RawData[3] = {0};
  uint8_t tmpreg = 0;
  float sensitivity = 0;
int i =0;
  L3GD20_Read(&tmpreg,L3GD20_CTRL_REG4_ADDR,1);
  L3GD20_Read(tmpbuffer,L3GD20_OUT_X_L_ADDR,6);
  /* check in the control register 4 the data alignment (Big Endian or Little Endian)*/
  if(!(tmpreg & 0x40))
    for(i=0; i<3; i++)
      RawData[i]=(int16_t)(((uint16_t)tmpbuffer[2*i+1] << 8) + tmpbuffer[2*i]);
  else
    for(i=0; i<3; i++)
      RawData[i]=(int16_t)(((uint16_t)tmpbuffer[2*i] << 8) + tmpbuffer[2*i+1]);
  /* Switch the sensitivity value set in the CRTL4 */
  switch(tmpreg & 0x30)
  case 0x00:
    sensitivity=L3G_Sensitivity_250dps;
    break;
  case 0x10:
    sensitivity=L3G_Sensitivity_500dps;
    break;
  case 0x20:
    sensitivity=L3G_Sensitivity_2000dps;
    break;
  /* divide by sensitivity */
  for(i=0; i<3; i++)
    pfData[i]=(float)RawData[i]/sensitivity;
  * @brief  Configure the Mems to compass application.
  * @param  None
  * @retval None
void Demo_CompassConfig(void)
  LSM303DLHCMag_InitTypeDef LSM303DLHC_InitStructure;
  LSM303DLHCAcc_InitTypeDef LSM303DLHCAcc_InitStructure;
  LSM303DLHCAcc_FilterConfigTypeDef LSM303DLHCFilter_InitStructure;
  /* Configure MEMS magnetometer main parameters: temp, working mode, full Scale and Data rate */
  LSM303DLHC_InitStructure.Temperature_Sensor = LSM303DLHC_TEMPSENSOR_DISABLE;
  LSM303DLHC_InitStructure.MagOutput_DataRate =LSM303DLHC_ODR_30_HZ ;/*!< Output Data Rate = 30 Hz */
  LSM303DLHC_InitStructure.MagFull_Scale = LSM303DLHC_FS_8_1_GA; /*!< Full scale = \B18.1 Gauss */
  LSM303DLHC_InitStructure.Working_Mode = LSM303DLHC_CONTINUOS_CONVERSION; /*!< Continuous-Conversion Mode */
  LSM303DLHC_MagInit(&LSM303DLHC_InitStructure);
   /* Fill the accelerometer structure */
  LSM303DLHCAcc_InitStructure.Power_Mode = LSM303DLHC_NORMAL_MODE; /*! Normal Mode */
  LSM303DLHCAcc_InitStructure.AccOutput_DataRate = LSM303DLHC_ODR_50_HZ;  /*! OUT data rate */
  LSM303DLHCAcc_InitStructure.Axes_Enable= LSM303DLHC_AXES_ENABLE;
  LSM303DLHCAcc_InitStructure.AccFull_Scale = LSM303DLHC_FULLSCALE_2G; /*! Full Scale selection */
  LSM303DLHCAcc_InitStructure.BlockData_Update = LSM303DLHC_BlockUpdate_Continous; /*! output register Data Update */
 // LSM303DLHCAcc_InitStructure.BlockData_Update =LSM303DLHC_BlockUpdate_Single;   /*! output register Data Update */
  LSM303DLHCAcc_InitStructure.Endianness=LSM303DLHC_BLE_LSB; /*!< Little Endian: data LSB @ lower address */
  LSM303DLHCAcc_InitStructure.High_Resolution=LSM303DLHC_HR_ENABLE;/*! High Resolution enabling */
 // LSM303DLHCAcc_InitStructure.High_Resolution=LSM303DLHC_HR_DISABLE ;/*! High Resolution enabling */
  /* Configure the accelerometer main parameters */
  LSM303DLHC_AccInit(&LSM303DLHCAcc_InitStructure);
  /* Fill the accelerometer LPF structure */
  LSM303DLHCFilter_InitStructure.HighPassFilter_Mode_Selection =LSM303DLHC_HPM_NORMAL_MODE;
  LSM303DLHCFilter_InitStructure.HighPassFilter_CutOff_Frequency = LSM303DLHC_HPFCF_16;
  LSM303DLHCFilter_InitStructure.HighPassFilter_AOI1 = LSM303DLHC_HPF_AOI1_DISABLE;
  LSM303DLHCFilter_InitStructure.HighPassFilter_AOI2 = LSM303DLHC_HPF_AOI2_DISABLE;
  /* Configure the accelerometer LPF main parameters */
  LSM303DLHC_AccFilterConfig(&LSM303DLHCFilter_InitStructure);
* @brief Read LSM303DLHC output register, and calculate the acceleration ACC=(1/SENSITIVITY)* (out_h*256+out_l)/16 (12 bit rappresentation)
* @param pnData: pointer to float buffer where to store data
* @retval None
void Demo_CompassReadAcc(float* pfData)
  int16_t pnRawData[3];
  uint8_t ctrlx[2];
  uint8_t buffer[6], cDivider;
  uint8_t i = 0;
  float LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_2g;
  /* Read the register content */
         *  read content of control regsiter so as to check
      * 1.BlockData_Update
       * 2.Endianness
       * 3.AccFull_Scale
       * 4.High_Resolution
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_CTRL_REG4_A, ctrlx,2);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_CTRL_REG1_A, ctrlx,2);
 * Output Register X acceleration
 * X-axis acceleration data.
 * The value is expressed as two’s complement.
  //LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_X_L_A, buffer, 6);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_X_H_A, buffer, 1);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_X_L_A, buffer+1, 1);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_Y_H_A, buffer+2, 1);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_Y_L_A, buffer+3, 1);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_Z_H_A, buffer+4, 1);
  LSM303DLHC_Read(ACC_I2C_ADDRESS, LSM303DLHC_OUT_Z_L_A, buffer+5, 1);
  if(ctrlx[1]&0x40)
    cDivider=64;
  else
    cDivider=16;
  /* check in the control register4 the data alignment*/
  if(!(ctrlx[0] & 0x40) || (ctrlx[1] & 0x40)) /* Little Endian Mode or FIFO mode */
    for(i=0; i<3; i++)
      pnRawData[i]=((int16_t)((uint16_t)buffer[2*i+1] << 8) + buffer[2*i])/cDivider;
  else /* Big Endian Mode */
    for(i=0; i<3; i++)
      pnRawData[i]=((int16_t)((uint16_t)buffer[2*i] << 8) + buffer[2*i+1])/cDivider;
  if(ctrlx[1]&0x40)
    /* FIFO mode */
    LSM_Acc_Sensitivity = 0.25;
  else
    /* normal mode */
    /* switch the sensitivity value set in the CRTL4*/
    switch(ctrlx[0] & 0x30)
    case LSM303DLHC_FULLSCALE_2G:
      break;
    case LSM303DLHC_FULLSCALE_4G:
      LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_4g;
      break;
    case LSM303DLHC_FULLSCALE_8G:
      LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_8g;
      break;
    case LSM303DLHC_FULLSCALE_16G:
      LSM_Acc_Sensitivity = LSM_Acc_Sensitivity_16g;
      break;
  /* Obtain the mg value for the three axis */
  for(i=0; i<3; i++)
    pfData[i]=(float)pnRawData[i]/LSM_Acc_Sensitivity;
  * @brief  calculate the magnetic field Magn.
* @param  pfData: pointer to the data out
  * @retval None
void Demo_CompassReadMag (float* pfData)
  static uint8_t buffer[6] = {0};
  uint8_t CTRLB = 0;
  uint16_t Magn_Sensitivity_XY = 0, Magn_Sensitivity_Z = 0;
  uint8_t i =0;
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_CRB_REG_M, &CTRLB, 1);
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_OUT_X_H_M, buffer, 1);
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_OUT_X_L_M, buffer+1, 1);
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_OUT_Y_H_M, buffer+2, 1);
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_OUT_Y_L_M, buffer+3, 1);
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_OUT_Z_H_M, buffer+4, 1);
  LSM303DLHC_Read(MAG_I2C_ADDRESS, LSM303DLHC_OUT_Z_L_M, buffer+5, 1);
  /* Switch the sensitivity set in the CRTLB*/
  switch(CTRLB & 0xE0)
  case LSM303DLHC_FS_1_3_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_1_3Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_1_3Ga;
    break;
  case LSM303DLHC_FS_1_9_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_1_9Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_1_9Ga;
    break;
  case LSM303DLHC_FS_2_5_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_2_5Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_2_5Ga;
    break;
  case LSM303DLHC_FS_4_0_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_4Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_4Ga;
    break;
  case LSM303DLHC_FS_4_7_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_4_7Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_4_7Ga;
    break;
  case LSM303DLHC_FS_5_6_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_5_6Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_5_6Ga;
    break;
  case LSM303DLHC_FS_8_1_GA:
    Magn_Sensitivity_XY = LSM303DLHC_M_SENSITIVITY_XY_8_1Ga;
    Magn_Sensitivity_Z = LSM303DLHC_M_SENSITIVITY_Z_8_1Ga;
    break;
  for(i=0; i<2; i++)
    pfData[i]=(float)((int16_t)(((uint16_t)buffer[2*i] << 8) + buffer[2*i+1])*1000)/Magn_Sensitivity_XY;
  pfData[2]=(float)((int16_t)(((uint16_t)buffer[4] << 8) + buffer[5])*1000)/Magn_Sensitivity_Z;
  * @brief  Inserts a delay time.
  * @param  nTime: specifies the delay time length, in 10 ms.
  * @retval None
void Delay(__IO uint32_t nTime)
  TimingDelay = nTime;
  while(TimingDelay != 0);
  * @brief  Decrements the TimingDelay variable.
  * @param  None
  * @retval None
void TimingDelay_Decrement(void)
  if (TimingDelay != 0x00)
    TimingDelay--;
  * @brief  Basic management of the timeout situation.
  * @param  None.
  * @retval None.
uint32_t LSM303DLHC_TIMEOUT_UserCallback(void)
  return 0;
  * @param  None.
  * @retval None.
uint32_t L3GD20_TIMEOUT_UserCallback(void)
  return 0;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
