Good day everyone! :) Direction Cosine Matrix IMU need help~
Question asked by Sage on Mar 21, 2014
Latest reply on Mar 28, 2014 by Sage
Hello, I'm a newbie programmer here and is currently toying with my STM32F3_Discovery. My initial value of x, y and z of gyro printed are not 0, so I ventured on and found out about Kalman Filter and this, DCM. I wish to learn both, starting with the latter and so I arrived at some problems of which I do not yet comprehend. Hopefully someone here is willing to guide me of showing me some examples of this programming. When I tried to write matrix equation using array, it stripped off the gyro and other related functions (like magnetometer and accelerometer). And as I program into it next time and tried to print values, it gives me the old code of printing instead of the renewed one. I find this puzzling.. Also, I wish to learn how to program using rotation matrix instead of quaternion as I have not completely understood the latter yet. Thank you for noticing and your patience for reading through to the end. :D
Here is some part of my code:
#define ABS(x)         (x < 0) ? (-x) : x
#define L3G_Sensitivity_250dps     (float)   114.285f         /*!< gyroscope sensitivity with 250 dps full scale [LSB/dps] */
#define L3G_Sensitivity_500dps     (float)    57.1429f        /*!< gyroscope sensitivity with 500 dps full scale [LSB/dps] */
#define L3G_Sensitivity_2000dps    (float)    14.285f          /*!< gyroscope sensitivity with 2000 dps full scale [LSB/dps] */
#define PI                         (float)     3.14159265f
#define LSM_Acc_Sensitivity_2g     (float)     1.0f            /*!< accelerometer sensitivity with 2 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_4g     (float)     0.5f            /*!< accelerometer sensitivity with 4 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_8g     (float)     0.25f           /*!< accelerometer sensitivity with 8 g full scale [LSB/mg] */
#define LSM_Acc_Sensitivity_16g    (float)     0.0834f         /*!< accelerometer sensitivity with 12 g full scale [LSB/mg] */
  RCC_ClocksTypeDef RCC_Clocks;
__IO uint32_t TimingDelay = 0;
__IO uint32_t UserButtonPressed = 0;
__IO float HeadingValue = 0.0f;
float MagBuffer[3] = {0.0f}, AccBuffer[3] = {0.0f}, Buffer[3] = {0.0f};
uint8_t Xval, Yval, Zval = 0x00;
__IO uint8_t DataReady = 0;
__IO uint8_t PrevXferComplete = 1;
float fNormAcc,fSinRoll,fCosRoll,fSinPitch,fCosPitch = 0.0f, RollAng = 0.0f, PitchAng = 0.0f;
float fTiltedX,fTiltedY = 0.0f;
int R_Matrix[3][3] = {{1,0,0},{0,1,0},{0,0,1}}; // R = Rotation Matrix
int Qp_Matrix[3][1] = {{0},{0},{0}};            // Qg = R Qp  Qg is vector ground, Qp is plane
uint32_t timerFlag=0;
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  uint8_t i = 0;
  /* SysTick end of count event each 10ms */
  RCC_GetClocksFreq(&RCC_Clocks);
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
  /* Initialize LEDs and User Button available on STM32F3-Discovery board */
  STM_EVAL_LEDInit(LED3);
  STM_EVAL_LEDInit(LED4);
  STM_EVAL_LEDInit(LED5);
  STM_EVAL_LEDInit(LED6);
  STM_EVAL_LEDInit(LED7);
  STM_EVAL_LEDInit(LED8);
  STM_EVAL_LEDInit(LED9);
  STM_EVAL_LEDInit(LED10);
  STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_EXTI);
  /* Reset UserButton_Pressed variable */
  UserButtonPressed = 0x00;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  UARTConfig();
  TIMConfig();
  /* Infinite loop */
  while (1)
    DataReady = 0x00;
    /* Demo Gyroscope */
    Demo_GyroConfig();
      /* Read Gyro Angular data */
      Demo_GyroReadAngRate(Buffer);
      /* Update autoreload and capture compare registers value*/
      Xval = ABS((int8_t)(Buffer[0]));
      Yval = ABS((int8_t)(Buffer[1]));
      Zval = ABS((int8_t)(Buffer[2]));
      LEDOff();
      if ( Xval>Yval)
        if ((int8_t)Buffer[0] > 5.0f)
          // LD10 On
          STM_EVAL_LEDOn(LED10);
        if ((int8_t)Buffer[0] < -5.0f)
          // LD3 On
          STM_EVAL_LEDOn(LED3);
      else
        if ((int8_t)Buffer[1] < -5.0f)
          // LD6 on
          STM_EVAL_LEDOn(LED6);
        if ((int8_t)Buffer[1] > 5.0f)
          // LD7 On
          STM_EVAL_LEDOn(LED7);
      sprintf(buf,"Xval=%d\t Yval=%d\t Zval=%d\r\n",Xval, Yval, Zval);
      UART4_directprint(buf);
      GPIO_ReadInputDataBit(GPIOF, GPIO_Pin_2);
     //Demo Compass
      Demo_CompassConfig();
      Demo_CompassReadMag(MagBuffer);
      Demo_CompassReadAcc(AccBuffer);
      for(i=0;i<3;i++)
        AccBuffer[i] /= 100.0f;
      fNormAcc = sqrt((AccBuffer[0]*AccBuffer[0])+(AccBuffer[1]*AccBuffer[1])+(AccBuffer[2]*AccBuffer[2]));
      fSinRoll = -AccBuffer[1]/fNormAcc;
      fCosRoll = sqrt(1.0-(fSinRoll * fSinRoll));
      fSinPitch = AccBuffer[0]/fNormAcc;
      fCosPitch = sqrt(1.0-(fSinPitch * fSinPitch));
     if ( fSinRoll >0)
       if (fCosRoll>0)
         RollAng = acos(fCosRoll)*180/PI;
       else
         RollAng = acos(fCosRoll)*180/PI + 180;
     else
       if (fCosRoll>0)
         RollAng = acos(fCosRoll)*180/PI + 360;
       else
      if ( fSinPitch >0)
       if (fCosPitch>0)
            PitchAng = acos(fCosPitch)*180/PI;
       else
          PitchAng = acos(fCosPitch)*180/PI + 180;
     else
       if (fCosPitch>0)
            PitchAng = acos(fCosPitch)*180/PI + 360;
       else
      if (RollAng >=360)
        RollAng = RollAng - 360;
      if (PitchAng >=360)
        PitchAng = PitchAng - 360;
      fTiltedX = MagBuffer[0]*fCosPitch+MagBuffer[2]*fSinPitch;
      fTiltedY = MagBuffer[0]*fSinRoll*fSinPitch+MagBuffer[1]*fCosRoll-MagBuffer[1]*fSinRoll*fCosPitch;
      HeadingValue = (float) ((atan2f((float)fTiltedY,(float)fTiltedX))*180)/PI;
      if (HeadingValue < 0)
        HeadingValue = HeadingValue + 360;
      if ((RollAng <= 40.0f) && (PitchAng <= 40.0f))
        if (((HeadingValue < 25.0f)&&(HeadingValue >= 0.0f))||((HeadingValue >=340.0f)&&(HeadingValue <= 360.0f)))
          STM_EVAL_LEDOff(LED3);
          STM_EVAL_LEDOff(LED6);
          STM_EVAL_LEDOff(LED7);
          STM_EVAL_LEDOff(LED4);
          STM_EVAL_LEDOff(LED8);
          STM_EVAL_LEDOff(LED9);
          STM_EVAL_LEDOff(LED5);
        else  if ((HeadingValue <70.0f)&&(HeadingValue >= 25.0f))
          STM_EVAL_LEDOn(LED9);
          STM_EVAL_LEDOff(LED10);
        else  if ((HeadingValue < 115.0f)&&(HeadingValue >= 70.0f))
        else  if ((HeadingValue <160.0f)&&(HeadingValue >= 115.0f))
          STM_EVAL_LEDOn(LED5);
        else  if ((HeadingValue <205.0f)&&(HeadingValue >= 160.0f))
        else  if ((HeadingValue <250.0f)&&(HeadingValue >= 205.0f))
          STM_EVAL_LEDOn(LED4);
        else  if ((HeadingValue < 295.0f)&&(HeadingValue >= 250.0f))
        else  if ((HeadingValue < 340.0f)&&(HeadingValue >= 295.0f))
          STM_EVAL_LEDOn(LED8);
      else
        LEDOff();
