STM32F429-discovery TFT Display VSYNC signal conflict with DAC#1
Question asked by Christopher Pappas on Feb 14, 2014
Latest reply on Feb 14, 2014 by Clive One
It appears as though the TFT Displays VSYNC signal (pa4) is in use in RGB-mode, and as a result, I can't set it to function as AFIO DAC#1 output (pa4), as it seems to cause the display to turn all white. DAC#2 output (pa5) works ok, but I was hoping to get a stereo output using both DAC pins. Can the TFT be set to run in MCU-mode, or any other mode that does not require a VSYNC signal?
