Speed of STM32F10vct6 FSMC interfacing with TFT LCD
Question asked by sruthi on Aug 8, 2016
Latest reply on Aug 8, 2016 by Clive One
Hi, I am working with SSD1963 7"TFT(800x480) with stm32f10vct6 controller. Right now refresh rate that I am able to achieve is 5 FPS. Is that the maximum speed? May I get much more speed with the same controller?  please take a look FSMC INIT code and SSD1963 init code that I’m using are given below.
FSMC Init
void LCD_FSMCConfig(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
/*-- FSMC Configuration ------------------------------------------------------*/
  /* FSMC_Bank1_NORSRAM4 timing configuration */
  p.FSMC_AddressSetupTime = 0;
  p.FSMC_AddressHoldTime = 0;
  p.FSMC_DataSetupTime = 1;
  p.FSMC_BusTurnAroundDuration = 0;
  p.FSMC_CLKDivision = 1;
  p.FSMC_DataLatency = 0;
  p.FSMC_AccessMode = FSMC_AccessMode_B;
  /* FSMC_Bank1_NORSRAM4 configured as follows:
        - Data/Address MUX = Disable
        - Memory Type = SRAM
        - Data Width = 16bit
        - Write Operation = Enable
        - Extended Mode = Disable
        - Asynchronous Wait = Disable */
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC_Bank1_NORSRAM4 */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
  * @brief  Initializes the FSMC NOR/SRAM Banks according to the
  *   specified parameters in the FSMC_NORSRAMInitStruct.
  * @param FSMC_NORSRAMInitStruct : pointer to a FSMC_NORSRAMInitTypeDef
  *   structure that contains the configuration information for
  *   the FSMC NOR/SRAM specified Banks.
  * @retval : None
void FSMC_NORSRAMInit(FSMC_NORSRAMInitTypeDef* FSMC_NORSRAMInitStruct)
  /* Check the parameters */
  assert_param(IS_FSMC_NORSRAM_BANK(FSMC_NORSRAMInitStruct->FSMC_Bank));
  assert_param(IS_FSMC_MUX(FSMC_NORSRAMInitStruct->FSMC_DataAddressMux));
  assert_param(IS_FSMC_MEMORY(FSMC_NORSRAMInitStruct->FSMC_MemoryType));
  assert_param(IS_FSMC_MEMORY_WIDTH(FSMC_NORSRAMInitStruct->FSMC_MemoryDataWidth));
  assert_param(IS_FSMC_BURSTMODE(FSMC_NORSRAMInitStruct->FSMC_BurstAccessMode));
  assert_param(IS_FSMC_WAIT_POLARITY(FSMC_NORSRAMInitStruct->FSMC_WaitSignalPolarity));
  assert_param(IS_FSMC_WRAP_MODE(FSMC_NORSRAMInitStruct->FSMC_WrapMode));
  assert_param(IS_FSMC_WAIT_SIGNAL_ACTIVE(FSMC_NORSRAMInitStruct->FSMC_WaitSignalActive));
  assert_param(IS_FSMC_WRITE_OPERATION(FSMC_NORSRAMInitStruct->FSMC_WriteOperation));
  assert_param(IS_FSMC_WAITE_SIGNAL(FSMC_NORSRAMInitStruct->FSMC_WaitSignal));
  assert_param(IS_FSMC_EXTENDED_MODE(FSMC_NORSRAMInitStruct->FSMC_ExtendedMode));
  assert_param(IS_FSMC_WRITE_BURST(FSMC_NORSRAMInitStruct->FSMC_WriteBurst));
  assert_param(IS_FSMC_ADDRESS_SETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressSetupTime));
  assert_param(IS_FSMC_ADDRESS_HOLD_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressHoldTime));
  assert_param(IS_FSMC_DATASETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataSetupTime));
  assert_param(IS_FSMC_TURNAROUND_TIME(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_BusTurnAroundDuration));
  assert_param(IS_FSMC_CLK_DIV(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_CLKDivision));
  assert_param(IS_FSMC_DATA_LATENCY(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataLatency));
  assert_param(IS_FSMC_ACCESS_MODE(FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AccessMode));
  /* Bank1 NOR/SRAM control register configuration */
  FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank] =
            (uint32_t)FSMC_NORSRAMInitStruct->FSMC_DataAddressMux |
            FSMC_NORSRAMInitStruct->FSMC_MemoryType |
            FSMC_NORSRAMInitStruct->FSMC_MemoryDataWidth |
            FSMC_NORSRAMInitStruct->FSMC_BurstAccessMode |
            FSMC_NORSRAMInitStruct->FSMC_WaitSignalPolarity |
            FSMC_NORSRAMInitStruct->FSMC_WrapMode |
            FSMC_NORSRAMInitStruct->FSMC_WaitSignalActive |
            FSMC_NORSRAMInitStruct->FSMC_WriteOperation |
            FSMC_NORSRAMInitStruct->FSMC_WaitSignal |
            FSMC_NORSRAMInitStruct->FSMC_ExtendedMode |
            FSMC_NORSRAMInitStruct->FSMC_WriteBurst;
  if(FSMC_NORSRAMInitStruct->FSMC_MemoryType == FSMC_MemoryType_NOR)
    FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank] |= (uint32_t)BCR_FACCEN_Set;
  /* Bank1 NOR/SRAM timing register configuration */
  FSMC_Bank1->BTCR[FSMC_NORSRAMInitStruct->FSMC_Bank+1] =
            (uint32_t)FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressSetupTime |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AddressHoldTime << 4) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataSetupTime << 8) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_BusTurnAroundDuration << 16) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_CLKDivision << 20) |
            (FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_DataLatency << 24) |
             FSMC_NORSRAMInitStruct->FSMC_ReadWriteTimingStruct->FSMC_AccessMode;
  /* Bank1 NOR/SRAM timing register for write configuration, if extended mode is used */
  if(FSMC_NORSRAMInitStruct->FSMC_ExtendedMode == FSMC_ExtendedMode_Enable)
    assert_param(IS_FSMC_ADDRESS_SETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressSetupTime));
    assert_param(IS_FSMC_ADDRESS_HOLD_TIME(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressHoldTime));
    assert_param(IS_FSMC_DATASETUP_TIME(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataSetupTime));
    assert_param(IS_FSMC_CLK_DIV(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_CLKDivision));
    assert_param(IS_FSMC_DATA_LATENCY(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataLatency));
    assert_param(IS_FSMC_ACCESS_MODE(FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AccessMode));
    FSMC_Bank1E->BWTR[FSMC_NORSRAMInitStruct->FSMC_Bank] =
              (uint32_t)FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressSetupTime |
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AddressHoldTime << 4 )|
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataSetupTime << 8) |
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_CLKDivision << 20) |
              (FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_DataLatency << 24) |
               FSMC_NORSRAMInitStruct->FSMC_WriteTimingStruct->FSMC_AccessMode;
  else
    FSMC_Bank1E->BWTR[FSMC_NORSRAMInitStruct->FSMC_Bank] = 0x0FFFFFFF;
  * @brief  Enables or disables the specified NOR/SRAM Memory Bank.
  * @param FSMC_Bank: specifies the FSMC Bank to be used
  *   This parameter can be one of the following values:
  * @arg FSMC_Bank1_NORSRAM1: FSMC Bank1 NOR/SRAM1
  * @arg FSMC_Bank1_NORSRAM2: FSMC Bank1 NOR/SRAM2
  * @arg FSMC_Bank1_NORSRAM3: FSMC Bank1 NOR/SRAM3
  * @arg FSMC_Bank1_NORSRAM4: FSMC Bank1 NOR/SRAM4
  * @param NewState: new state of the FSMC_Bank.
  *   This parameter can be: ENABLE or DISABLE.
  * @retval : None
void FSMC_NORSRAMCmd(uint32_t FSMC_Bank, FunctionalState NewState)
  assert_param(IS_FSMC_NORSRAM_BANK(FSMC_Bank));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    /* Enable the selected NOR/SRAM Bank by setting the PBKEN bit in the BCRx register */
    FSMC_Bank1->BTCR[FSMC_Bank] |= BCR_MBKEN_Set;
  else
    /* Disable the selected NOR/SRAM Bank by clearing the PBKEN bit in the BCRx register */
    FSMC_Bank1->BTCR[FSMC_Bank] &= BCR_MBKEN_Reset;
SSD1963 Init
void SSD1963_Initial(void)
                vWrite_command(0x00E2);         //PLL multiplier, set PLL clock to 120M
                vWrite_Data_int(0x0022);                //N=0x36 for 6.5M, 0x23 for 10M crystal
                vWrite_Data_int(0x0003);
                vWrite_Data_int(0x0054);
                vWrite_command(0x00E0);  // PLL enable
                vWrite_Data_int(0x0001);
                delayus(10);
                vWrite_Data_int(0x0003);                            // now, use PLL output as system clock
                delayus(10);
                vWrite_command(0x0001);  // software reset
                delayus(20);
                vWrite_command(0x00E6);         //PLL setting for PCLK, depends on resolution
                vWrite_Data_int(0x0033);
                vWrite_command(0x00B0);        //LCD SPECIFICATION
                vWrite_Data_int(0x0020); //24 bit TFT panel
//            vWrite_Data_int(0x0080);
//            vWrite_Data_int(0x0003);
//            vWrite_Data_int(0x001F);
//            vWrite_Data_int(0x0001);
//            vWrite_Data_int(0x00DF);
//            vWrite_Data_int(0x0000);
                vWrite_Data_int(0x0000); //Hsync+Vsync +DE mode  TFT mode
                vWrite_Data_int((799>>8));  //Set HDP
                vWrite_Data_int(31);
    vWrite_Data_int(479>>8);  //Set VDP
                vWrite_Data_int(223);
                vWrite_command(0x00B4);        //HSYNC
                vWrite_Data_int(0x04);  //Set HT
                vWrite_Data_int(0x20);
                vWrite_Data_int(0x00);
                vWrite_Data_int(0x2E);
                vWrite_Data_int(0xD2);
//            vWrite_Data_int(0x1f);
//            vWrite_Data_int(0x00);  //Set HPS
//            vWrite_Data_int(0xd2);
//            vWrite_Data_int(0x00);                                                   //Set HPW
                vWrite_command(0x00B6);        //VSYNC
                vWrite_Data_int(0x02);   //Set VT
                vWrite_Data_int(0x0D);
                vWrite_Data_int(0x17);
                vWrite_Data_int(0x16);
//            vWrite_Data_int(0x0c);
//            vWrite_Data_int(0x00);  //Set VPS
//            vWrite_Data_int(0x22);
//            vWrite_Data_int(0x00);                                //Set VPW
                vWrite_Data_int(0x00);  //Set FPS
                                vWrite_command(0x002A);
                vWrite_Data_int(0x01);
                vWrite_Data_int(0xDF);
                                vWrite_command(0x002B);
                vWrite_Data_int(0x03);
                vWrite_Data_int(0x1F);
