L6470 int_speed limitation - not compatible with my motor
Question asked by ginsburg.ran on Apr 24, 2013
Latest reply on Sep 22, 2013 by Enrico Poli
I'm exploring the EVAL6470H with my stepper motor.
according to the motor electrical parameters, the INT_SPEED should be around 2000 steps/s. The problem is that the L6470 has a maximal limitation of 976 steps/s for this parameter.
So if I want my application to work at 6000 steps/s, I cannot get a steady current while accelerating to that point (I can, though, "trick" the parameters so I would get the wanted current at 6000 steps/s).
Why do you limit the INT_SPEED parameter so low, and do you have a workaround solution for me, or is it impossible to use this motion control with my motor?
Thank you.
