Reading data from internal flash
Question asked by vnv on May 30, 2016
Hi all,
could someone please give a hint on how to read from flash.             I have tried to set value inside flash and then read it afterwards inside the code but it doesn't work, it reads 0.
Inside ld file I have done following.
/* Specify the memory areas */
MEMORY
FLASH (rx)      : ORIGIN = 0x8000000, LENGTH = 2048K
RAM (xrw)      : ORIGIN = 0x20000000, LENGTH = 192K
CCMRAM (rw)      : ORIGIN = 0x10000000, LENGTH = 64K
DATA (rwx)        : ORIGIN = 0x080E0000, LENGTH = 128k
/* Define output sections */
SECTIONS
    .user_data :
      . = ALIGN(4);
         *(.user_data)
      . = ALIGN(4);
    } > DATA
Inside the code I set memory location to value of 1. Then try to use that value to blink led.
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2016 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "stm32f4xx_hal.h"
#include "gpio.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PV */
__attribute__((__section__(".user_data"))) const uint8_t userConfig[64];
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
void write_data_to_flash(uint8_t address, uint32_t data){
    HAL_FLASH_Unlock();
      __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR | FLASH_FLAG_PGAERR | FLASH_FLAG_PGSERR );
     FLASH_Erase_Sector(FLASH_SECTOR_11, VOLTAGE_RANGE_3);
      HAL_FLASH_Program(TYPEPROGRAM_BYTE, &userConfig[address], 1);
      HAL_FLASH_Lock();
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
    uint8_t pause;
  /* USER CODE END 1 */
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  /* USER CODE BEGIN 2 */
 write_data_to_flash(0,0xAABBCCDD);
//  write_data_to_flash(4,0xBBCCDDEE);
//  write_data_to_flash(2,0xCC);
//  write_data_to_flash(3,0xDD);
  pause = userConfig[0];
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
      HAL_GPIO_TogglePin(LD4_GPIO_Port,LD4_Pin);
      HAL_Delay(pause*1000);
  /* USER CODE END 3 */
/** System Clock Configuration
void SystemClock_Config(void)
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 50;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
#ifdef USE_FULL_ASSERT
   * @retval None
  /* USER CODE BEGIN 6 */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
