Bug report CubeMX V 4.14.0
Question asked by reed.matthew.003 on May 11, 2016
Latest reply on May 11, 2016 by ForumSTM32.ForumSTM3
Cube is corrupting the .cproject file, resulting in no symbol table for the debug elf file.
Create a project with Cube, edit run, test etc.
Create a 'Release' build (No-debug).
Back into Cube, modify and re-generate.
Back in Eclipse, select Debug configuration, do a build.  No symbol table.
Comparing the .cproject file we see this change that when reverted restores the symbol table.
Correupt .cprogram file:
<sourceEntries>
<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name="Src"/>
<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name="Inc"/>
</sourceEntries>
Good .cprogram file
<sourceEntries>
<entry flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/>
</sourceEntries>
(also, on this forum, if you click "Click for help about adding HTML formatting." you get pop-up about sharepoint server).
-Matt
