STM32F7audio
Question asked by nawel.frikha on Apr 15, 2016
Latest reply on Apr 26, 2016 by nawel.frikha
Je veux intégrer le filtre arm biquad casquade dans la demo loopback de st mais je n’arrive pas . voici  le code :
* @file    BSP/Src/audio_loopback.c
* @author  MCD Application Team
* @version V1.0.2
* @date    18-November-2015
* @brief   This example code shows how to use the audio feature in the
*          stm32746g_discovery driver
* @attention
* <h2><center>&copy; COPYRIGHT(c) 2015 STMicroelectronics</center></h2>
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
*   1. Redistributions of source code must retain the above copyright notice,
*      this list of conditions and the following disclaimer.
*   2. Redistributions in binary form must reproduce the above copyright notice,
*      this list of conditions and the following disclaimer in the documentation
*      and/or other materials provided with the distribution.
*   3. Neither the name of STMicroelectronics nor the names of its contributors
*      may be used to endorse or promote products derived from this software
*      without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS “AS IS”
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ——————————————————————*/
#include “main.h”
#include <stdio.h>
#include “string.h”
#define ARM_MATH_CM7
#include “core_cm7.h”
#include “arm_math.h”
#include “stm32f7xx.h”
#include “stdbool.h”
/** @addtogroup STM32F7xx_HAL_Examples
/** @addtogroup BSP
/* Private typedef ———————————————————–*/
typedef enum
BUFFER_OFFSET_NONE = 0,
BUFFER_OFFSET_HALF = 1,
BUFFER_OFFSET_FULL = 2,
}BUFFER_StateTypeDef;
#define AUDIO_BLOCK_SIZE   ((uint32_t)512)
#define BLOCKSIZE            ((uint32_t)128)
#define AUDIO_BUFFER_IN    AUDIO_REC_START_ADDR     /* In SDRAM */  //0x0800=2048
#define AUDIO_BUFFER_FILTRE   (AUDIO_REC_START_ADDR + (AUDIO_BLOCK_SIZE * 2)) /* In SDRAM */
#define AUDIO_BUFFER_OUT   (AUDIO_REC_START_ADDR + (AUDIO_BLOCK_SIZE * 4)) /* In SDRAM */
#define AUDIO_BUFFER_IN1    (AUDIO_REC_START_ADDR + (AUDIO_BLOCK_SIZE * 6))     /* In SDRAM */  //0x0800=2048
#define AUDIO_BUFFER_FILTRE1   (AUDIO_REC_START_ADDR + (AUDIO_BLOCK_SIZE * 8)) /* In SDRAM */
/* Private define ————————————————————*/
/* Private macro ————————————————————-*/
/* Private variables ———————————————————*/
extern uint32_t  audio_rec_buffer_state;
/* Private function prototypes ———————————————–*/
static void AudioLoopback_SetHint(void);
/* Private functions ———————————————————*/
#define numStages    13
//arm_biquad_cascade_df2T_instance_f32 filtreprec;
float32_t  pState[26];
float32_t  pCoeffs[65]={6.47838194538537,-5.63833463639715,0,-0.697402314363736,0,
1,-0.0334812348452013,-0.895962777668104,-0.0338083801197804,-0.896266347094799,
1,-1.59962148024071,0.695262684259369,-1.37413982115687,0.543870194931503,
1,-1.20422320134904,0.630533020513583,-1.1429432143631,0.586066508474033,
1,-1.07986712377598,0.729560256531613 ,-1.02677035697368,0.702540386918896,
1,-1.58794295912004,0.776219823791875,-1.55113669346191,0.743501114906827,
1,-0.921004723865756,0.762537481494472,-0.912100983564361,0.767008612923214,
1,-1.51850631095467,0.836089114425888,-1.51833646579472,0.835031151490734,
1,-0.847512904105293,0.840794074256209,-0.847412122419245,0.843572002136111,
1,-1.84248957262001,0.864944791885131,-1.83138216512215,0.85357067407514,
1,-1.24162379879317,0.865238218278357,-1.24264949505176,0.86575255109575,
1,-0.802309608367053,0.905107118813219,-0.802582204542893,0.905433385638613,
1,-0.775924227958755,0.984244432624096,-0.775924823409485,0.984247415819846};
uint32_t numBlocks = AUDIO_BLOCK_SIZE/BLOCKSIZE;
uint32_t i;
bool firstStart = false;
* @brief  Audio Play demo
* @param  None
* @retval None
void AudioLoopback_demo (void)
AudioLoopback_SetHint();
/* Initialize Audio Recorder */
if (BSP_AUDIO_IN_OUT_Init(INPUT_DEVICE_DIGITAL_MICROPHONE_2, OUTPUT_DEVICE_HEADPHONE, 90, DEFAULT_AUDIO_IN_FREQ) == AUDIO_OK)
BSP_LCD_SetBackColor(LCD_COLOR_WHITE);
BSP_LCD_SetTextColor(LCD_COLOR_GREEN);
BSP_LCD_DisplayStringAt(0, BSP_LCD_GetYSize() – 95, (uint8_t *)”  AUDIO RECORD INIT OK  “, CENTER_MODE);
else
BSP_LCD_SetTextColor(LCD_COLOR_RED);
BSP_LCD_DisplayStringAt(0, BSP_LCD_GetYSize() – 95, (uint8_t *)”  AUDIO RECORD INIT FAIL”, CENTER_MODE);
BSP_LCD_DisplayStringAt(0, BSP_LCD_GetYSize() – 80, (uint8_t *)” Try to reset board “, CENTER_MODE);
/* Display the state on the screen */
BSP_LCD_SetTextColor(LCD_COLOR_BLUE);
BSP_LCD_DisplayStringAt(0, BSP_LCD_GetYSize() – 80, (uint8_t *)”Microphones sound streamed to headphones”, CENTER_MODE);
/* Initialize SDRAM buffers */
memset((int16_t*)AUDIO_BUFFER_IN, 0, AUDIO_BLOCK_SIZE*2);
memset((int16_t*)AUDIO_BUFFER_FILTRE, 0, AUDIO_BLOCK_SIZE*2);
memset((float32_t*)AUDIO_BUFFER_IN1, 0, AUDIO_BLOCK_SIZE*2);
memset((float32_t*)AUDIO_BUFFER_FILTRE1, 0, AUDIO_BLOCK_SIZE*2);
memset((int16_t*)AUDIO_BUFFER_OUT, 0, AUDIO_BLOCK_SIZE*2);
audio_rec_buffer_state = BUFFER_OFFSET_NONE;
/* Initialize filtre */
if (firstStart == false)
{   arm_biquad_cascade_df2T_init_f32(&filtreprec, numStages,pCoeffs,pState);
firstStart = true;
arm_biquad_cascade_df2T_instance_f32 filtreprec = {numStages, pState, pCoeffs};
/* Start Recording */
BSP_AUDIO_IN_Record((int16_t*)AUDIO_BUFFER_IN, AUDIO_BLOCK_SIZE);
/*  filtrer le signal de parole */
for(i=0; i < numBlocks; i++)
arm_q15_to_float((int16_t*)AUDIO_BUFFER_IN+(i*BLOCKSIZE),(float32_t*)AUDIO_BUFFER_IN1, AUDIO_BLOCK_SIZE*2);
arm_biquad_cascade_df2T_f32(&filtreprec,(float32_t*)AUDIO_BUFFER_IN1,(float32_t*)AUDIO_BUFFER_FILTRE1, AUDIO_BLOCK_SIZE);
arm_float_to_q15((float32_t*)AUDIO_BUFFER_FILTRE1,(int16_t*)AUDIO_BUFFER_FILTRE+(i*BLOCKSIZE),AUDIO_BLOCK_SIZE*2);
/* Start Playback */
BSP_AUDIO_OUT_SetAudioFrameSlot(CODEC_AUDIOFRAME_SLOT_02);
BSP_AUDIO_OUT_Play((int16_t*)AUDIO_BUFFER_OUT, AUDIO_BLOCK_SIZE * 2);
while (1)
/* Wait end of half block recording */
while(audio_rec_buffer_state != BUFFER_OFFSET_HALF)
if (CheckForUserInput() > 0)
/* Stop Player before close Test */
BSP_AUDIO_OUT_Stop(CODEC_PDWN_SW);
return;
/* Copy recorded 1st half block */
memcpy((int16_t *)(AUDIO_BUFFER_OUT),
(int16_t *)(AUDIO_BUFFER_FILTRE),
AUDIO_BLOCK_SIZE);
/* Wait end of one block recording */
while(audio_rec_buffer_state != BUFFER_OFFSET_FULL)
return;
/* Copy recorded 2nd half block */
memcpy((int16_t *)(AUDIO_BUFFER_OUT + (AUDIO_BLOCK_SIZE)),
(int16_t *)(AUDIO_BUFFER_FILTRE + (AUDIO_BLOCK_SIZE)),
AUDIO_BLOCK_SIZE);
/* Stop recorder */
BSP_AUDIO_IN_Stop(CODEC_PDWN_SW);
return;
* @brief  Display Audio Record demo hint
* @param  None
* @retval None
/* Clear the LCD */
BSP_LCD_Clear(LCD_COLOR_WHITE);
/* Set Audio Demo description */
BSP_LCD_FillRect(0, 0, BSP_LCD_GetXSize(), 90);
BSP_LCD_SetTextColor(LCD_COLOR_WHITE);
BSP_LCD_SetBackColor(LCD_COLOR_BLUE);
BSP_LCD_SetFont(&Font24);
BSP_LCD_DisplayStringAt(0, 0, (uint8_t *)”AUDIO LOOPBACK EXAMPLE”, CENTER_MODE);
BSP_LCD_SetFont(&Font12);
BSP_LCD_DisplayStringAt(0, 30, (uint8_t *)”Press User button for next menu”, CENTER_MODE);
/* Set the LCD Text Color */
BSP_LCD_DrawRect(10, 100, BSP_LCD_GetXSize() – 20, BSP_LCD_GetYSize() – 110);
BSP_LCD_DrawRect(11, 101, BSP_LCD_GetXSize() – 22, BSP_LCD_GetYSize() – 112);
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
