CMSIS Timers: What I'm doing wrong?
Question asked by whitewool on Mar 3, 2016
Latest reply on Mar 7, 2016 by FTITI.Walid
I’m starting to work with STM32L4 and I need to use CMSIS FreeRTOS.
I own a NUCLEO-L476RG evaluation board, I already tested the FreeRTOS_ThreadCreation example, so I started to test CMSIS Timers.
To make things quick I decided simply modify the Thread_Creation example by adding the creation of a Timer to make a Led blink.
A very simple code, following the example indication on the documentation.
I’m really confused, this simple program compiles but don’t run on the NUCLEO, the timer don’t exist, and I’m stuck and really I don’t understand what stupid wrong error I’m making.
I’ve done a lot of tries changing the order of operations, or launching the timer from a thread previously created but nothing, or other, but nothing works.
Can anyone help me to understand the problem?
Thanks for any hint.
  * @file    FreeRTOS/FreeRTOS_ThreadCreation/Src/main.c
  * @author  MCD Application Team
  * @version V1.3.0
  * @date    29-January-2016
  * @brief   Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2016 STMicroelectronics International N.V.
  * All rights reserved.</center></h2>
  * Redistribution and use in source and binary forms, with or without
  * modification, are permitted, provided that the following conditions are met:
  * 1. Redistribution of source code must retain the above copyright notice,
  *    this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  *    this list of conditions and the following disclaimer in the documentation
  *    and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of other
  *    contributors to this software may be used to endorse or promote products
  *    derived from this software without specific written permission.
  * 4. This software, including modifications and/or derivative works of this
  *    software, must execute solely and exclusively on microcontroller or
  *    microprocessor devices manufactured by or for STMicroelectronics.
  * 5. Redistribution and use of this software other than as permitted under
  *    this license is void and will automatically terminate your rights under
  *    this license.
  * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
  * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
  * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
  * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "main.h"
#include "cmsis_os.h"
typedef enum
  THREAD_1 = 0,
  THREAD_2
} Thread_TypeDef;
osThreadId LEDThread1Handle, LEDThread2Handle;
static void toggleLED(void const *argument);
  * @param  None
  * @retval None
int main(void)
  /* STM32L4xx HAL library initialization:
       - Configure the Flash prefetch
       - Systick timer is configured by default as source of time base, but user
         can eventually implement his proper time base source (a general purpose
         timer for example or other time source), keeping in mind that Time base
         duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
         handled in milliseconds basis.
       - Set NVIC Group Priority to 4
       - Low Level Initialization
  HAL_Init();
  /* Configure the System clock to 80 MHz */
  SystemClock_Config();
  /* Initialize LED */
  BSP_LED_Init(LED2);
     /* Define a timer with “toggleLED” as callback */
  osTimerDef(TIMER, toggleLED);
     /* Create the timer */
  osTimerId id1 = osTimerCreate(osTimer(TIMER), osTimerPeriodic,NULL);
  /* Start the timer */
  osTimerStart(id1, 200);
  /* Start scheduler */
  osKernelStart();
  /* We should never get here as control is now taken by the scheduler */
  for (;;);
  * @brief  Toggle LED2
    BSP_LED_Toggle(LED2);
  * @brief  System Clock Configuration
  *         The system Clock is configured as follows :
  *            System Clock source            = PLL (MSI)
  *            SYSCLK(Hz)                     = 80000000
  *            HCLK(Hz)                       = 80000000
  *            AHB Prescaler                  = 1
  *            APB1 Prescaler                 = 1
  *            APB2 Prescaler                 = 1
  *            MSI Frequency(Hz)              = 4000000
  *            PLL_M                          = 1
  *            PLL_N                          = 40
  *            PLL_R                          = 2
  *            PLL_P                          = 7
  *            PLL_Q                          = 4
  *            Flash Latency(WS)              = 4
  * @param  None
  * @retval None
void SystemClock_Config(void)
  /* MSI is enabled after System reset, activate PLL with MSI as source */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
  RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 40;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLP = 7;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    /* Initialization Error */
    while(1);
  /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
     clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
    while(1);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
