Finding the code size in IAR
Question asked by p.raul on Mar 2, 2016
Latest reply on Mar 7, 2016 by AvaTar
is the.map fiel correct way to determine the size of the code?
I have written a module and wanted to find the size of the code (ROM and RAM).I first took a STM32F* template built it and noted the figures from the .map file (readonly code memory,readonly data memory ,readwrite data memory)
Then I added my module and call it in one of the while loop and then  built it and noted the figures from the .map file  again(readonly code memory1,readonly data memory1 ,readwrite data memory1)
Now is the code size of the new module i have made will be the difference of the two map file figures.
in Keil when we load the hex file we come to know about the size of the code before run time.I have seen teh size reported by the Keil and IAR are different.Is this due to the internal in built  funciton used by each compiler IAR vs Keil?
