lis3lv02dq's ODR can not greater than 160Hz
Question asked by kong.deliang on Oct 10, 2013
Latest reply on Nov 18, 2013 by Thiago.Reis@ST
The RDY is used to indicate a new data is available. The problem is that the ODR can not greater than 160Hz,otherwise after a period of time of dataoutput,the RDY goes low,and the value of STATUS_REG is changed to 0x77(why??). The initial code follows:
Write_Command(CTRL_REG1, 0xE7);
Delay_Time(10);
Write_Command(CTRL_REG2, 0x14);
Delay_Time(10);
Write_Command(CTRL_REG3, 0x18);
Delay_Time(10);
Write_Command(CTRL_REG2, 0x44);
Delay_Time(10);
