LPS25HB reading
Question asked by zhang.rui.008 on Oct 13, 2016
Hi
I have 2 LPS25HB pressure sensors. I moved them from exact the same level to another level. The readings from both sensors are different. The start points are different and the slope of the value change is also different!
However, i just programmed to read the value out without editing any reference or offset, or differential setting.
Can i correct the results by editing some registers, if so which registors?
Rui
