Unable to connect to TCP Socket (server) using SPWF01S
Question asked by galicia_silva.armand on Apr 1, 2015
Latest reply on Apr 1, 2015 by Gerardo Gallucci
Hi all,
I really hope somebody can help me on this. I'm using a STEVAL-IDW001v1 with SPWF01S module integrated. I'm trying to connect to a local server using TCP socket, right now I'm using the server socket.exe example from the wifi training hands on doc(page). Use this command:
"at+s.sockon=192.168.69.79,32000,t"
and I get this error
"ERROR: Failed to connect"
any idea?
here my dump keys:
# Dumping All Configuration Keys:
#  nv_manuf = ST
#  nv_model = SPWF01SA1
#  nv_serial = 4313D12184
#  nv_wifi_macaddr = 00:80:E1:FF:DC:D7
#  blink_led = 1
#  user_desc = anonymous
#  localecho1 = 1
#  console_uart = 1
#  console1_speed = 115200
#  console1_hwfc = 0
#  console1_enabled = 1
#  console2_speed = 115200
#  console2_enabled = 0
#  localecho2 = 1
#  console3_enabled = 0
#  console3_speed = 115200
#  localecho3 = 1
#  wifi_tx_msdu_lifetime = 0
#  wifi_rx_msdu_lifetime = 0
#  wifi_rts_threshold = 3000
#  wifi_ssid = 43:6F:6C:69:62:72:69:41:70:70:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_ssid_len = 10
#  wifi_mode = 1
#  wifi_auth_type = 0
#  wifi_rssi_thresh = 0
#  wifi_rssi_hyst = 0
#  wifi_ap_idle_timeout = 120
#  wifi_beacon_loss_thresh = 10
#  wifi_priv_mode = 2
#  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_key_lens = 00:00:00:00
#  wifi_wep_default_key = 0
#  wifi_wpa_psk_raw = C3:87:6B:99:19:8D:B7:AB:6A:3A:B7:B8:46:9F:CF:4E:20:66:07:AA:69:89:7C:65:96:DC:62:83:7C:2D:92:A5
#  wifi_wpa_psk_text = chupala11veces
#  ip_use_dhcp = 1
#  ip_use_httpd = 1
#  ip_mtu = 1500
#  ip_hostname = iwm-FF-DC-D7
#  ip_apdomainname = captiveportal.net
#  ip_ipaddr = 192.168.0.50
#  ip_netmask = 255.255.255.0
#  ip_gw = 192.168.0.1
#  ip_dns = 192.168.0.1
#  ip_http_get_recv_timeout = 1000
#  ip_dhcp_timeout = 20
here my statistics:
# Status & Statistics:
#  version = 140225-02d76c4-SPWF01S
#  reset_reason = 2
#  conf_flag = 5
#  system_uptime = 4393
#  system_sleeptime = 0
#  gpio_enable = 0
#  captiveportal = 0
#  wifi_sup_ratemask = 0x003FFFCF
#  wifi_bas_rate_mask = 0x0000000F
#  wifi_state = 10
#  wifi_dtim_period = 1
#  wifi_gf_mode = 0
#  wifi_channelnum = 6
#  wifi_chan_activity2 = 0x00000FFE
#  wifi_max_tx_power = 18
#  wifi_reg_country = MX
#  wifi_num_assoc = 0
#  ip_ipaddr = 192.168.69.79
#  ip_gw = 192.168.69.1
#  ip_dns = 192.168.52.1
#  free_heap = 25104
#  min_heap = 23584
#  current_time = 10202
attached is the document where I'm working as a reference.
looking forward to hear from somebody :)
