Interrupt Problems
Question asked by be_senyor.ezra on Oct 12, 2010
Latest reply on Oct 12, 2010 by Clive One
hi
i have aquestion about Interrupts:
in all the example code that i saw i could never find where the program goes to in case of an Interrupt.
here is one of the exmple code i have from st site which the button activate external Interrupt but where does the program goes in that case??
  * @file    EXTI/main.c
  * @author  MCD Application Team
  * @version V3.3.0
  * @date    04/16/2010
  * @brief   Main program body
  * @copy
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2010 STMicroelectronics</center></h2>
#include "stm32f10x.h"
#include "stm32_eval.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Example
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* Initialize LED1 and Key Button mounted on STM3210X-EVAL board */
  STM_EVAL_LEDInit(LED1);
  STM_EVAL_PBInit(BUTTON_KEY, BUTTON_MODE_EXTI);
  /* Generate software interrupt: simulate a falling edge applied on Key Button EXTI line */
  EXTI_GenerateSWInterrupt(KEY_BUTTON_EXTI_LINE);
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
thanks...
