How to prevent low level driver from changings
Question asked by Patrik Schantl on Sep 9, 2014
Latest reply on Sep 9, 2014 by Erwan Y
Unfortunately, a few moments before I found out that I lost all changes I had manually done within the CAN low level drivers (changins in number of RX message buffers, filters, filter IDs, filter masks, ...). Just everything which I was not able to configure by using the SPC5 Application Configuration. I only wanted to change the compliler optimization level.
Is there a way, how I can prevent several files from beeing new generated or cleared when I generate the application configuration? Or what is the best way when I wanted to adapt a project (for example using DSPI) without loosing all changes in the other HAL components?
Best regards,
Patrik
