SPWF01SA IBSS
Question asked by geloso.pietro on Feb 25, 2015
Latest reply on Feb 26, 2015 by geloso.pietro
Hi, I'm using STEVAL-IDW001V1 and STEVAL-PCC018V1 boards.
I set up wifi into IBSS mode named "ADHOC" but I cannot detect it from the telephone or browser.
I've the impression I'm not creating the ADHOC network. Where's the issue?
I'm attaching data.
+WIND:2:Reset
+WIND:1:Poweron (141106-0950875-SPWF01S)
+WIND:13:ST SPWF01SA1 IWM: Copyright (c) 2012-2014 STMicroelectronics, Inc.  All rights Reserved.
+WIND:3:Watchdog Running
+WIND:0:Console active
+WIND:32:WiFi Hardware Started
+WIND:21:WiFi Scanning
+WIND:35:WiFi Scan Complete (0x0)
+WIND:19:WiFi Join:16:BD:EC:00:B3:C5
+WIND:25:WiFi Association with 'ADHOC' successful
+WIND:51:WiFi Handshake Complete
+WIND:24:WiFi Up:192.168.1.101
# Status & Statistics:
#  version = 141106-0950875-SPWF01S
#  reset_reason = 2
#  conf_flag = 5
#  system_uptime = 103
#  system_sleeptime = 0
#  gpio_enable = 0
#  captiveportal = 0
#  wifi_state = 10
#  wifi_bssid = 16:BD:EC:00:B3:C5
#  wifi_aid = 0
#  wifi_channelnum = 6
#  wifi_sup_rate_mask = 0x003FFFCF
#  wifi_bas_rate_mask = 0x0000000F
#  wifi_chan_activity2 = 0x00000020
#  wifi_max_tx_power = 18
#  wifi_reg_country =
#  wifi_dtim_period = 0
#  wifi_sleeping = 1
#  wifi_num_assoc = 0
#  ip_ipaddr = 192.168.1.101
#  ip_netmask = 255.255.255.0
#  ip_gw = 192.168.1.1
#  ip_dns = 208.67.222.222
#  ip_sock_open = 0
#  ip_sockd_port = 0
#  free_heap = 21656
#  min_heap = 20312
#  current_time = 2342
OK
# Dumping All Configuration Keys:
#  nv_manuf = ST
#  nv_model = SPWF01SA1
#  nv_serial = 4313D25167
#  nv_wifi_macaddr = 00:80:E1:FF:BA:C7
#  blink_led = 0
#  wind_off_low = 0x00000000
#  wind_off_medium = 0x00000000
#  wind_off_high = 0x00000000
#  user_desc = anonymous
#  escape_seq = at+s.
#  localecho1 = 0
#  console1_speed = 115200
#  console1_hwfc = 0
#  console1_enabled = 1
#  sleep_enabled = 0
#  standby_enabled = 0
#  standby_time = 10
#  wifi_tx_msdu_lifetime = 0
#  wifi_rx_msdu_lifetime = 0
#  wifi_operational_mode = 0x00000011
#  wifi_beacon_wakeup = 1
#  wifi_beacon_interval = 100
#  wifi_listen_interval = 0
#  wifi_rts_threshold = 3000
#  wifi_ssid = 41:44:48:4F:43:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_ssid_len = 5
#  wifi_opr_rate_mask = 0x00003FCF
#  wifi_mode = 2
#  wifi_auth_type = 0
#  wifi_atim_window = 0
#  wifi_powersave = 0
#  wifi_tx_power = 18
#  wifi_rssi_thresh = 0
#  wifi_rssi_hyst = 0
#  wifi_ap_idle_timeout = 120
#  wifi_beacon_loss_thresh = 10
#  wifi_priv_mode = 0
#  wifi_wep_keys[0] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[1] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[2] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_keys[3] = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wep_key_lens = 00:00:00:00
#  wifi_wep_default_key = 0
#  wifi_wpa_psk_raw = 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
#  wifi_wpa_psk_text =
#  ip_use_dhcp = 0
#  ip_use_httpd = 1
#  ip_mtu = 1500
#  ip_hostname = iwm-FF-BA-C7
#  ip_apdomainname = captiveportal.net
#  ip_dns = 192.168.1.1
#  ip_http_get_recv_timeout = 3000
#  ip_dhcp_timeout = 20
#  ip_sockd_timeout = 250
OK
